Hello all. I'm a newbie, so excuse the lack of basic knowledge, but i have a 320s 2021 with a 2 way fridge and am headed out to boondock for 10 days. The area I'm headed is heavily treed, which is great for shade, but not for charging the solar and keeping the fridge running. How do you maintain cold fridge temps if parked in the shade? THANK YOU
0 ·
We were at this primitive campground, Twin Peaks in Colorado for ten days. Batteries topped off before noon each day.
A quicker option would to buy a suitcase panel with its own controller. That way, you could just set it up and connect to your battery with the alligator clips that it comes with....super easy. I'm guessing your battery is in the propane tub. Depending on how far you are from sunlight, you may just need to buy and extension for the alligator cable.
I bought this Renogy model and have been very happy with it. It comes with a controller and alligator clips. You can always add a port later if you like. I bought a second Victron controller because I like the bluetooth function and...they say there are less losses if you mount the controller closer to the battery.
Good luck!
