Well, it had to happen... scope creep has started to appear in my trip planning and I m considering adding a more northward leg to my trip next month. All very tentative, but I am considering adding a few days in the Grand Tetons to my trip. So, I know it will be cold at night there, possibly into the 20‘s. Would you winterized for this? My fresh water tank is inside and I will boondock and run the Alde. Thoughts?
0 ·
More on the smoke - Even east of the Black Hills I've had smoke, heavy haze. Absolutely no golden hour photography for three days and today is no better. The badlands have been lost in the haze.
J.D. & Sue
Probably a good idea.
The heat tape will cover your hookup hose - just make sure all the smaller pipes for the internal lines don't get too cold. I personally would not use either T@B water system and would just carry water if it got down in the low 20s overnight. 28-32, no problem - but that depends on how long it's that low.
Otherwise, at night when it's below freezing, your Tab will be relatively warm inside, so no need to winterize inside, I'd think.
Don't depend on it staying warm inside if it's below freezing when you're towing though, it cools off pretty quickly at 55mph (been there, done that - got an icicle hanging from the faucet - grin).
