I Have a 2020 Tab 400. I discovered Alde fluid under the dinette table. It came from the front left side under seat storage area. Tracing back further, the source is from a loose convector connection under the shower pan. It can been seen by removing the wood access panel under the door. There is no way to get to it from this spot as the shower drain p trap is in the way. Anyone have experience in taking up the shower pan and its plywood support subfloor? It appears to me to be the only way to get a clamp tool on the end of that Alde hose. Thanks in advance.
                2020 Tab 400 Boondock--2006 Lexus GX470.
0 ·
