Hi, I couldn't find appropriate category and struck out searching prior discussions. I did reduce size of photo, I hope it's enough. At several locations along the arched white trim is yellow-tan blotching. Are we alone? Is it a problem? Can it be cosmetically improved. Thank you!
2020 T@B 400 BDL towed with 2019 Nissan Frontier Pro-4X Tucson, AZ
White plastic RV trim can develop yellow-beige discoloration due to various factors, including exposure to sunlight (UV radiation), heat, oxidation, and even some environmental pollutants
Here are several methods to address and remove the yellowing:
1. Cleaning and restoration
