NuCamp warning about Sunflare Solar Panel Failures July, 2025
Apparently, this has been floating around since July 11.  Can't find this document at the NuCamp page, or at the Sunflare page.  Apparently, at the NuCamp gathering this was discussed as a "known issue"...but seems like nobody had ever heard of it!
Link to the actual .pdf is below. There is also the Sunflare .pdf on the issue.
Thank you for contacting us regarding your nuCamp trailer and the Sunflare flexible solar panel.
Sunflare has identified two potential concerns affecting a small number of panels:
In fewer than 2% of units, under certain conditions, electrical arcing may occur inside the solar panel assembly. This can cause visible damage, smoke or arcing.
Some panels may also experience cellular breakdown that creates a blue haze around the cells and results in low voltage output.
Your safety is our highest priority, and we are committed to resolving these issues quickly.
Next Steps:
Please review the attached notices in detail.
Inspect your panels as described.
If you see discoloration, burn marks, holes, smoke, or a noticeable drop in performance, disconnect the panel immediately.
Contact your dealer or service provider for assistance.
nuCamp Owner Sunflare Panel Notice – includes inspection instructions, controller locations by model, and claim procedures.
Sunflare Customer Safety Notice
If you have any questions or would like help submitting a claim, please reply to this email or contact us at warranty@nucamprv.com. We are here to assist you and ensure any necessary repairs are handled promptly.
Thank you for your understanding and for being part of the nuCamp community.
Sincerely,
The nuCamp Warranty Team
  • Here are some photos from a 2024 400 and a Cirrus camper (year unknown).  Other owners have piped up and said they have the same things happening.  This is the Cirrus, hard to tell the scale here.
    The 2024 400
  • We attended the first Sunflare talk at uCamp. To the best of my memory, the Sunflare rep said it was a misalignment on the assembly line that allowed a short circuit soon after the panel was fully connected and activated (as their press release above also seems to state).
    NuCamp rep said in their products it predominately affected a limited number of 2025 T@B 400s. She also said they believe they know which trailers were affected and most were still on dealer lots. Also, if you're battery has been installed awhile and the panel experienced no issues that you most likely don't have a panel from the defective run.
    Not making any judgements, just trying to share what I believe was said.
    Homeport - Virginia Beach, VA
  • Thanks for that info.
  • We put one of those 310W panels on our 320S this past winter. I'll have to keep an eye on it. Thanks for the info.
  • 2024 320S BBC.
    It came with 2x190W panels...I wonder if those are on the list?
  • It came with 2x190W panels...I wonder if those are on the list?
    That makes me wonder if Sunflare can tell you if your panels are from the bad lots by the serial number? I took a picture of the labeling on the back of my new panel before installing. There's a barcode and a number. I'll have to contact Sunflare to see if they have any information.
  • I might have one of these on my tab 360 built last fall. I have been very disappointed with the performance of my two 190 watt panels, so this might explain my problem. Here are photos that show the issue that I am seeing. Look closely at the left-hand panel.
    T@B 360 Black Canyon, 2021 Jeep Grand Cherokee V6, Maryland
    (previous 2018, T@B 320 Outback)
  • ChrisFix
    edited August 2025
    2024 320S BBC.
    Yes they are...in fact, the way it reads is that those are the main culprits...However at the uCamp Sunflair tech session, they said it was "mainly" in units built in 2025, so look at your manufacturing date. They did state emphatically, that if it was a bad panel, it would fail as soon as it was powered, leaving a noticable burn mark on the panel itself. So if yours are working, you should be fine.
    "We want to inform you of an issue identified in a small number of Sunflare flexible solar panels, specifically the 190 watt model, but also possibly in 180 watt and 310 watt models. In fewer than 2% of units shipped, we discovered that under certain conditions, electrical arcing may occur due to a slight internal misalignment during manufacturing. In rare cases, this could lead to visible damage or smoke from the solar panel."
  • my solar performance has always been bad, so I suspect that I have always been limping along with only one panel.
  • donmontalvo
    edited August 2025
    Thanks for the info!
  • My two-panel system is working badly. Maybe the right one is still working and the left one is failing.
  • AnOldUR
    edited August 2025
    ... due to a slight internal misalignment during manufacturing. In rare cases, this could lead to visible damage or smoke from the solar panel."
    "... should be fine ..."
    "... could lead to visible damage ..."
    This all sounds intentionally very vague.
    So, this misalignment can be present and not show visible signs? How does the misalignment affect performance? Is there potential for it to cause problems as the panel ages?
    They've found the cause and with minimal quality control in place they should be able to identify panels made while there was a misalignment. A reputable company would issue a recall on all the panels with potential problems.
    I did send Sunflare the bar code number from my panel. It will interesting to see if I get a reply. Curious if that number is linked to an individual panel or general part number?
    edit to add that it's been over a week and no reply from Sunflare.
  • These photos show the Solar Panel damage for a Cirrus 620 Manufactured August 2024.
    Close-up and full panel shots.
    NuCamp assures me that the damage will be covered under Warranty.
