2021 400. Just repacked the bearings this spring and finally got it out on the road this weekend. Things were fine until I was at a stop light and squeezed the brake controller manual lever just to test it. Upon letting off the truck’s brakes the vehicle didn’t creep forward as it always does when I release the brakes.
As I accelerated I could feel resistance. Pulled over, disconnected the 7-pin thinking it was an electrical issue. Plugged it back in and still felt it dragging. Finally I decided to back up a few feet….this did the trick and all was well. Several miles down the road I could tell the brakes were grabbing again as I was going downhill but losing speed when I let off the gas.
Pulled out the temp gun and the passenger side drum was 210 and the driver side was 144. So something isn’t releasing and it doesn’t seem to be electrical in nature. Anybody else have an issue like this? I read that maybe the return springs in the drum mechanism could be the culprit?
You did not mention it in your post, but have you checked to confirm that the emergency breakaway/brakes controller pin is properly secured? If the switch is activated (pin pulled out), that would make an electrical connection between the trailer battery and the electric brakes. (Other parts of your post tend to be inconsistent with that possibility, such as backing up and the brakes apparently disengaging for a period of time, so this is a "just in case" response.)
2020 Tacoma TRD Off-Road
After that incident I religiously check those wires. I also think this issue is mechanical and not related to any electrical problems.
I’m at a loss. I can put new shoes in but I have no idea if that really is my problem. BOTH wheels seems to be exhibiting this behavior which led me to believe that me leaving the drums off for a couple of weeks back in February to pack bearings led to contamination of the shoes somehow.
https://imgur.com/a/2eEc7pU
John, Northern California
I thought about this after watching your video and seeing the actuator arm getting hung up until you push it back to its normal position. Maybe when you back up the trailer, that is enough to push the magnet back, but eventually it is possible that it will again push outward toward the brake drum.
This is a good video that talks about the magnet operation and the spring behind it. Worth watching, if nothing else for the helpful information it provides:
https://www.youtube.com/watch?v=ZEJ2DUdMhE8
After posting the above, I came across this video, which shows what a bad spring looks like:
https://www.youtube.com/shorts/JIKy4WO0oaU
My drums are in decent shape. I was hoping to find a shop that would turn them but I'm having trouble with that. The two shops I talked to said they just replace them as that is more cost effective. The problem I'm having is the Dexter drums for the 400 are rated at 4k lbs. when most other 10" brake assemblies are rated at 3.5k lbs. and are MUCH cheaper. New Dexter drums are $210 each which is out of the question. Are there aftermarket options I'm just not seeing?
"Just Enough"
Sorry you're dealing with this.
What's different with the Nucamp other than shoddy workmanship and dangerously deficient wiring? Flimsy frame? Not sure that would twist the axle enough to change brake to hub alignment.
A puzzle.
