Boondock - Off-Road Capability?
Hello, fairly new T@b 400 Boondock owner (2023). We are happy with our camper but have found that it does not seem to have any off pavement capability. We have struggled with cabinets falling off, drawers breaking and others issues while traveling on forest roads. The forest roads were traveling are fairly smooth, and roads I could easily navigate in a passenger vehicle. Does anyone have any experience with this?
I've seen Mandy Lea's video, but if I did that with my T@b, I am pretty sure everything would fall off!
  • swiftwave
    swiftwave Member Posts: 50
    I have a 2020 T@B 400 Boondock Lite.  I’ve towed it up to Tuktoyaktuk on the Dempster Highway, twice.  It’s a long gravel road.  I slightly deflate the tires to soften the bumps and I drive fairly slowly.  I’ve had a few interior breakages, all reasonably easy to fix.  I'm generally able to make my repairs stronger than stock, though not always as aesthetically pleasing.  I secure cabinets and drawers with aftermarket latches, so they can’t open during travel.  I latch the top of the bathroom door so the hinges alone don’t absorb all the bumps.
    Sorry to hear about the breakages on your trailer.  Hopefully, most of the weaknesses have already been revealed and remedied!
    2020 Chevrolet Colorado ZR2
    with the 2.8 litre 4-cylinder Duramax diesel.
    qhumberd Administrator, Moderator Posts: 913
    Travel trailers, despite the branding, have been termed “rolling earthquakes” for a reason. The torsion bar suspension on the 400 does help soften the ride, but when you have all that cabinetry above the frame, it can’t help but loosen somewhat over time. I’ve seen how mine bounces on forest roads, and I avoid them except for short distances and low speed.
  • AnOldUR
    AnOldUR Member Posts: 1,761
    We tow our 320S (non-boondock) with a lifted Jeep Wrangler. I feel silly as I creep very slowly along dirt roads.
  • Grumpy_G
    Grumpy_G Member Posts: 788
    edited August 2025
    Despite the marketing the rubber torsion axles are unsuitable for actually going off pavement. Even a bumpy paved road can get the trailer tires to bounce off the the ground. According to the axle data sheet the wheel has a mere 1.5" of upward travel at rated load.
    One member here ( @rzabel ) converted his trailer to Timbren independent rear suspension similar to what most "proper" off-road campers use. Details here: https://tab-rv.vanillacommunity.com/discussion/comment/214535
  • Cherokee
    Cherokee Member Posts: 346
    We've modified our 2019 320 Boondock Edge to be able to to very moderate 4x4 roads. When the cabinets come loose, we glue them back together with epoxy and we've added turn knob latching hardware. The biggest limitation is the limited travel in the "pitched" axle. Unfortunately, the Timbren suspension offers about the same 2" of travel. However, with similar modifications you should be able to something like this: https://www.youtube.com/watch?v=qzb8FRAA1Bs
    California, USA
  • snappycnb
    snappycnb Member Posts: 4
    Thank you for your suggestions everyone - I will look into this!
    edited August 2025
    Many Tab owners get out off the beaten path.  But: the Tab frames are still considered "light duty", and there is a limit to what the trailers can stand up to.  Cherokee's video is a pretty good example of what many owners (carefully) do.  I've done many Forest Service roads, etc.
    This thread (and the threads linked in the comments) explain how these Dexter frames are put together, and how some owners have lost the "huck bolts" connecting the basic frame pieces.
    And, I think the "offroad" usage gets a bit abused for Tabs.  They are very good at "soft roading", but climbing rocks is not what a Tab can really do.
    Other than a little additional ground clearance, the "Boondock" package is mostly cosmetic. The trailers themselves are not built to be any more rugged than the standard versions.
    That doesn't mean they are not well-built trailers that are capable of being towed off the beaten path (as many owners have attested), but they are not not truly designed for navigating rugged terrain.
  • rzabel
    rzabel Member Posts: 33
    We got to try out our upgrades earlier this summer with a month long trip fishing and camping in Idaho and Montana.  In addition to the increased clearance, the greatest benefit was how well it rode.  I tried putting shocks on the original axles/suspension and it really made no difference. The Timbrens rode as if I had very good shocks, dampening the big bumps.  The interior is all new and built to take some abuse too, so we were very happy to find everything in it's place when we arrived at a campsite, instead of on the floor as happened too many times before!  We didn't test it much, mostly just forest service roads, a few with ruts and washouts as can be expected, but it is so much better suited to that now.
    2008 Dutchman/Thor T@B T1
    1948 Spartan Manor
    2003 GMC Yukon XL 2500 TV
  • AndreaPalumbo
    AndreaPalumbo Member Posts: 16
    edited June 22
    Right about the time this thread was started, we took our T@B up in the National Forest past Darrington Washington, on Suiattle River Road. There are several little off shoots, many of which should accommodate our trailers (and only ours… anything much larger than a 400 likely won't fit).
    The photo in my avatar was taken up there. It did well, though there is about a mile of pretty extreme washboards though. I also seemed to have broken off my sewer vent cap somewhere in those woods. And… it got some minor scratches along the side due to the thick trees and brush (parts of the road were just barely wide enough for our rig… I recommend scouting the side roads on foot or bring a bike to ensure nobody is up there… would be rough to have to back out all the way)
    I accidentally hit a NASTY pot hole in the Montana backroads too. I'm really surprised it didn't damage the T@B or the Chevy. Both seemed to have survived. Dumb luck I suppose.
    2025 T@B 400 (original owner)
    2013 Silverado 1500 (T.V.)
    Stanwood Washington
  • AnOldUR
    With over 60K of towing miles, we've been on some rough terrain. Washboards, potholes, train tracks, cattle crossings … all take their toll, but never found that having the extra clearance of a Boondock would have made a difference.
    We took our 320S (non-boondock) for service at Miller in PA this spring. Preston noticed some uneven tire wear leading him to look further. Turns out that one of the above mentions obstacles must have bent the axle. I'll blame one particular unseen cattle crossing hit at high speed for the damage.
    The good news is that Preston had practically new standard axles from customers who he had installed boondock axles for. Personally don't see the need for the extra ground clearance and like that our T@B fits into our garage. We're scheduled for the repair mid-July.
