Is this normal...I've only used city water twice...this weekend while on city water the tank seemed to fill up...I drained it an seems water still drains from there when using city water...any insight appreciated
Not sure of the year of your trailer, but if you have the Nautilus, the check valve at the fresh water inlet could be the issue. Check that the screen at the inlet is pointed/faced out. If it is, then maybe look at the white button check valve behind it, does it move? Maybe it's stuck.
Debbie in Oregon Sold 2023 Tab 400 Sold 2018 T@B 320S
Yep. Typically a failure in the city water inlet check valve will result in water leaking out the city water port when using the pump and onboard water tank.
A failure in the pump check valve will result in the onboard water tank getting filled when using city water.
Having a Nautilus may add a few additional wrinkles depending on valve settings, but the basic concepts should be the same.
2015 T@B Max S (320) 2015 Nissan Frontier SV V6 4x4
If the pump check valve fails it would seem that a a catastrophe will ensue once the fresh water tank totally fills and continues expanding. Are there telltale signs that the check valve has failed and that water is being diverted to the fresh water tank early on once city water is turned on? It would seem that all one could do is listen intently for the sound of water running continuously. We typically start off at a campsite with totally drained lines and drained Alde so we hear city water filling everything and then the sound stops after several minutes. I would take somewhat longer to then fill the 25 gallon water tank.
Susan & Bill, Yarmouth, Maine 2024 T@B 400 Boondock Black Canyon 2024 Kia EV9
Good question and point.
Since freshwater tanks must vented in some manner (they wouldn't fill properly if they weren't) I would expect that eventually water would start emerging from the vent. (In my case the vent is located right above the FW tank fill port.)
Even if the vent were blocked, the FW tank would only pressurize to the level of the city water source--the same thing that happens in your plumbing under normal conditions. That said, the FW tank isn't normally under any pressure, so it might well suffer a failure in these circumstances.
My suspicion (and that's all it is) is that leaks in the pump check valve are usually pretty small. As a result, water trickles into the tank rather than gushing. As such, the tank will take a long time to overflow, and you might not hear anything unusual before discovering that your once-empty tank now has water in it!
What year trailer is it, or does it have a Nautilus panel. Most of the responses so far have been for trailers without Nautilus. You system is different.
Found out it was the water valve as you all guessed and I googled. Replaced and good to go...by an Airstream dealer no less...fyi...better than most repair places
https://tab-rv.vanillacommunity.com/discussion/6454/fresh-water-tank-mysteriously-filling-when-connected-to-city-water
Sold 2023 Tab 400
Sold 2018 T@B 320S
2024 Kia EV9
"Just Enough"
