Into the process of removing the Harris AGM batteries after 5 years and replacing them with a Litime 230AH lithium. Have spent a fair amount of time perusing the forum about the issue of the stock Wfco convertor/charger not being able to fully charge a lithium battery and fully understand the reasons for that. Am installing a Litime 40A charger along with the battery as a result. What I'm not clear about and have seen contradictory opinions on is whether the Wfco and the Litime charger can simultaneously be attached to the battery when on shore power or if the battery disconnect switch must be used to disconnect the battery from the Wfco when on shore power. Have the Victron MPPT solar charge controller on the trailer as well and that is never disconnected from the battery including when on shore power and the output of the Wfco is connected to the battery. Two chargers at the same time. What's the issue with having a third charger, the Wfco tied to the battery as well?
Thanks!
2020 Tab 400 BDL with Solar
2013 Tacoma TRD with towing package
Vermont
2025 Chevy Colorado Z71
SW Ohio
Curious about your use of a 10 A battery charger to charge your LiTime 230 Ah battery when you're at an RV park. How does it compare to letting the WFCO charge off the RV park's 30 AMP pedestal power?
PS, Pleasant surprise when I discovered solar stuff is cheap and tax free in AZ, can't wait to go back in another month or two. I plan to scale the off grid power on my JLUR this time.
2024 nuCamp T@b 320S Boondock Black Canyon (480W solar|200ah LiFePO4|1200W inverter)
2021 Jeep Wrangler Unlimited Rubicon (130W solar|100ah LiFePO4|DCDC|1000W inverter)
https://revkit.com/donmontalvo/ | https://donmontalvo.com
The WFCO can put out more than 10 amps, which is the only advantage, but it can't take the battery up to 100% and allow the battery to balance the cells as it need to do periodically. I don't have solar but I do have a suitcase 100W panel I can plug in as well that can also charge Lithium.
