Thanks for the tip about the brake wire. Will check it out.PXLated ásaid:Check the brake wire under the T@B - runs across from one brake to the other - mine was hanging way down - any further and it would have dragged on the ground. It's now gorilla taped tight.
Other than that, I'm at a loss cuz as you know, I never plan anything. It's wing it and go with the flow :-)
Thanks, yes, propane. I will take it for a refill. I am probably about 1/2 way down right now.OzT@b said:Check propane level.
Stock up on wine.
Stock up on chocolate.
No kidding!PXLated said:Put chocolate in fridge so you don't end up with one big melted together cocoa block.
I actually developed an app for my Windowsphone for the T@b. It has the ready-set-tow stuff, contact information, the battery status chart, social media links, and YouTube playlist with tips and tutorials.Sandra said:Don't forget to print out a couple of the Ready Set Tow cards. You can add in the "Don't Forget" items on the side - like stop the mail; turn off coffee pot, unplug the t.v., etc., pet food - whatever. But it's great to have in your hand when you are trying to either set up for the first time, or break camp and someone wants a tour. Helps you to not forget what to do.
J.D. & Sue
I'm a little nervous about my tires. The Tab is only one year old, and I have noticed some small cracks in the sidewalls near the rim. Is this dangerous?
Horrendous mileage, lol. Towing, I get between 9-11 on the highway. Back roads and slower 2 lane highways I usually get 12-13, if I am lucky. You will get better mileage, though, as they improved some on the newer models.Rolland said:Jenn, what kind of gas mileage do you get on your Jeep ? I am getting a 2016 and opted for the 3.73 gears and manual trans. My T@B will be a Max S at end of year.
