I don't plug in often, but recently as it was our only choice we plugged in at a campground. The electrical heat did not work. All other electrical items did; lights and pump okay.  I noticed no heat coming on after quite awhile.  I switched to propane and heat immediately worked.  I check all fuses, including the two hidden glass fuses in the Alde itself.  I know how to use the heater and hot water thermostat and had it on the appropriate settings.  Any ideas?
Thanks - Parlando
Alde Power Cord
having slipped out of the outlet.
Remove the round temperature knob. Then remove the black plastic spindle behind the knob. Using a flat screwdriver, gently pry off the back cover (you can see from the photos that the cover snaps onto the green circuit board itself at three points). Start at the rear where the wires come out of the cover. There are three very small Phillips head screws holding the circuit board to the front cover. Gently remove them (all these plastic parts are very brittle after all these years). You now have visual and physical access to the slide controls (no need to remove anything else). Simply clean the contact points using rubbing alcohol and a cotton swab. Do this several times to insure the contacts (top and bottom) are clean. The photos below are not in any particular order, but should give you an overall view of what you'll be dealing with. Hope this helps.
https://tab-rv.vanillacommunity.com/discussion/6381/fuse-finder#latest
https://us.v-cdn.net/5021717/uploads/editor/q4/kuwppa7w77ab.pdf
I ask, because propane for the Alde will work on 12V, as will the lights, fans, and water pump. Having 12V power to control those items while troubleshooting a 110/120V AC electrical issue can trick you into thinking you have AC power. It has for me in the past, which is why I disconnect the battery from the system when doing AC troubleshooting.
Since the Alde boiler runs on propane & the circulation pump actives to heat the cabin but neither happens on 120VAC it sounds like the Analog Control Panel thermostat function if fine. There is an issue with the 120VAC.
The Adle is a 12VDC unit. The only thing the 120VAC does is power the two electric resistive heat coils.
So possible causes are:
1) No 120VAC, check the Alde compartment output . . . with a meter of 120V fan/light/etc
2) Analog Panel is not sending the 'turn-on' signal . . . not sure how to troubleshoot at this time.
3) The Alde Control PCB 120VAC Relay(s) have failed.
Might be possible to hear or feel the relays activate (two person job).
If they, all three, activate then Analog Panel and relays are good.
4) Heat level Step 1 electrical coil has failed.
Might be possible to try increasing Analog Panel to Heat level Step 2.
If only coil 1 is bad, coil 2 would begin heating and not trip your house shore power 15/20A circuit.
You can also use an Ohm meter to check the electrical coil resistance.
One owner has reported the coils are in the 14 - 16 Ohms range (no idea if that is accurate)
See This Alde Thread
Wire Color to Terminal mapping.
Problem Solved!
Thanks to everyone who chimed in. I went back over every little thing I could find. I used my Victron today and noticed that I had current & power were negative when they should have been positive as I was plugged in. I checked and found that one of my circuit breakers was off. ( I thought I had turned them all back on.) So I turned it on, and turned on the heat and checked 45 minutes later. The radiator in the Alde was warm... not hot, but everything I read has said that the Electrical heat is slow, much slower than the Propane, so I think we are good. I've read that it is a good thing to start with Propane, and then switch to electric if you are in a spot that provides it. Thank you everyone. I do apologize if I was a goofball, but truly appreciate everyone's help. PS. My new tail lights arrive tomorrow and I'm hopeful that will solve that problem. -Parlando
