Hello all,
There are SO many options on Amazon now for a foldable panel. Just not sure which one to choose as the reviews are all over the place. I also noticed that some are 40 volt and some are 20 so that will definitely affect which controller to get as well. I was hoping to use one of the mini/mobile controllers but some are limited to 10 amp so that might be pushing it with a 20 volt panel.
Anyway, any suggestions/thoughts would be appreciated.
2025 Tab320S pulled by Ford Maverick
0 ·
Best practice is to buy a panel without an onboard controller and install a controller as close to the battery as possible. This will reduce voltage drop. When installed, our nuCamp trailers come with Victron products. For a 200W panel a 75/15 Victron controller will cover the requirements of most panel manufactures. That's a max of 75 volts allowed coming into the controller and it will output no more than 15 amps.
Something else to consider is the type of connection that you'll use. The most common has been SAE ports. I went that route because that's what I saw everyone else doing at the time. You may want to research Anderson PP15. I'm in the process of converting over to it.
2017 F-150
Coeur d'Alene, Idaho
The panel came with a controller, which I bypassed but left in place. I like the Victron products as well, so I added a second controller inside my propane/battery tub. It works great and I still have the controller that came with the panel in case anyone in my group needs to charge their batteries.
However, I recently upgraded to lithium but did not replace my converter....so I need my solar controller to get the batteries up to 100% SOC. I'm guessing there are a lot of other people with the same issue.
