Trim Panel Removal
I have a crack in my top trim panel on my 2020 Tab 400 (pictures attached). I'd like to remove the panel in order to patch it all up properly using backing. I have searched these forums and consulted ChatGPT and haven't cracked the code on how to remove these things. I don't see any screws on any of the panels (other than the wheel well) and don't see any kind of tape. I can slightly lift up the rails after I remove the weather strip, but as far as I can tell they are simply nestled into the backside of the keder rail. They seem brittle so I don't want to use any force until I know exactly how these things come off. Any guidance would be greatly appreciated! Thank you! :)
