I found a new 24 320 css with the convenience package. It didn't have the lithium upgrade package or the black canyon. So i want to add them my self. I bought the second bb battery and a multiplus 2000 but there is no room to install it?? Where did they put them in the css models? I also orders a sun flare 180w panel but its way different than the factory panel on the front. Its 65"x 45" approx and the factory is only 35"x45" with the wires under the panel. How is it a 180w panel but so much smaller. The one i got has surface mount mc4 connectors. What is the best way to get them into the wheel well area. Im guess i wont be able to run them into the same controller now. I bought a 100/30 but i dont know what the factory panel is or its specs. Plus i have a 220w portable panel i was going to wire into another 100/30. It looks like ill end up with 3 controllers now? Does anyone have a picture of the multiplus in a 320css. The only place i can see is maybe behind the factory fuse panel? I though i was just going to copy the factory and make a 320 css black canyon with lithium upgrade but this might not be possible.
0 ·
I found these in another post on this forum.
Southern Maryland
Oh dear, my memory: it's going.
I went out to take pictures and discovered that actually had I drilled a hole in the roof and installed something like this.
The panel looks like this:
That better than i found. The battery wiring is very helpful, but the mutiplus cant go there in a css, its shorter inside and my ac is right by the batteries. The only possible, and im not sure it is, is behind the wfco. Every other spot is full.
This is the same panel i got for the rear of mine. Its different than the factory panel as they go in the roof under the panel I found out. And sun flare does not sell the panel to the public, its a 180w mono crystalline panel. That gland looks like the right part for the job for sure. It kind of sucks because of the different type of panels i have to use 2 mppt controllers.
Huge improvement over the 100W factory installed panel ...
Yes, I believe the Multiplus was mounted on it's side. Unfortunately I can't locate the picture I saw. I was thinking of the same mod, but, it looked like such a tight fit I'm not sure it's worth the effort. I may just go with just an inverter to save space. It's unfortunate that Victron doesn't make a 2000W standalone inverter. On the other hand, it might be worth looking at a single larger capacity battery that would fit crossways in front of the wheel well. That would leave more room for the Multiplus. Battleborn, Renogy, and I think LiTime all make larger capactiy batteries in various form factors that might work. The next time I'm at my trailer I'll take some measurements.
