Solved - Battery change - what to do with heater cable on BattleBorn
JPPJPP Member Posts: 4
I am switching out the BattleBorn 100 ah Lithium battery, that came stock on the T@B 400 BD, with an SOK 208 ah lithium.  The BattleBorn has an externally switched low temperature heater in their battery.  There is a separate cable attached to the BB battery to activate the heater. I’m wondering what to do with this cable once I disconnect it?  I assume I can just cap off the end of this wire and leave it as is?  The SOK battery does not have an external switch, rather it has an internal switch that activates a heater if charging at temps below 2C.  I attached a pic showing the BB battery with the red heater cable wire attached.  Thanks.
T@B 400 Black Canyon, 2025
Chev Colorado
St Catharines, ON
