Need some gas bottle ideas for removal
MOS2
Member Posts: 60
Have a 2025 400 boondock black canyon with the large tub on the front.
Removing the LP gas bottle for refill is a pita . The bottle is held in place by a ring with a bolt and wing nut .
Not much room to loosen the wing nut by hand . I bet others have the same issue .
So what did you do to make revolving the bottle more user friendly ?
Thanks , Mike
I put in a longer bolt and added a spacer about 1/2 to 3/4 inches long to push the wing nut further out from the clamp. That gives me room to tighten the wing nut more easily.
2 -
I will give that a try . But not much room in there .2025 400 Boondock Black Canyon0
@MOS2, I experienced the same issue you describe. My solution for the last 3+ years is to use a removable zip tie. In my case, I discovered the tank didn’t really need to be held tight I place just secure.
2020 TAB 320 U
TV 2025 Telluride X Type1 -
We removed the hose holder in our original tub. Gave us more room.Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio1
No hose holder in the 25 400 ..the large tub has a section for the bottle but very limited room for removalSharon_is_SAM said:We removed the hose holder in our original tub. Gave us more room.2025 400 Boondock Black Canyon0 -
The longer bolt with a space work a little better but not great2025 400 Boondock Black Canyon0
MOS2 said:The “arm” of the handle slides up on the stem, freeing it from the nut inside. After each 180 degree turn of the handle, you can readjust the arm back 180 degrees, so that you can crank the nut another half-turn tighter/looser.
The ~3” handle length makes it possible for me to tighten the nut by hand, without scrounging up wrench of some sort.Charles & Judy, Santa Cruz, CA
2018 T@B 320 CS-S; Alde 3020; 4 cyl 2020 Subaru Outback Onyx XT0 -
You need to have a newer 400 with the larger tub to understand how much limited room there is to reach that wing nutckjs said:MOS2 said:The “arm” of the handle slides up on the stem, freeing it from the nut inside. After each 180 degree turn of the handle, you can readjust the arm back 180 degrees, so that you can crank the nut another half-turn tighter/looser.
The ~3” handle length makes it possible for me to tighten the nut by hand, without scrounging up wrench of some sort.2025 400 Boondock Black Canyon0 -
Home Depot had (has?) knurled round knobs with a threaded metal centre hole which might work with a 1/4-20 bolt.400 - 2019
St Catharines, ON0 -
When I changed from plastic tub to aluminum tub I rebuilt insides. Here's what I used to make it a little easier.
2018 TAB 320S
2020 Honda Ridgeline RTL
North Texas
Trips - 50 Mileage - @67k
"Our favorite trip will always be our next one"2 -
We use a portable step for the 400. Use step to gain better leverage lifting tank. Still requires effort. Love the lockable and well designed front storage. Good news, we only fill once a year0
I used JB Weld to glue the bolt to the OEM strap so I could loosen the wingnut with one hand. A plastic nut would make it even easier. I'm not sure why NuCamp chose not to make a square hole in the strap so a standard carriage bolt could be used without it spinning in the hole.Adventure Cats living in the Pacific NW USA
2022 NuCamp T@B 320S Boondock
2023 Volkswagen ID.4 Pro S Plus AWD1
