2025 Tab 360 w-Lithium Upgrade
Is anyone aware of the existence of an electrical diagram for the Tab 360 with the Lithium Upgrade Package?
2025 T@B 360 Black Canyon with Lithium Upgrade “Serenity”
2020 Honda Passport Touring
  • Yoshi_TAB
    Yoshi_TAB Member Posts: 586
    Hi,
     Nucamp does not provide them,  even to dealers (i have asked our 360 dealer if Nucamp gives them to dealers and he said no ).
    Are you looking to install a Multiplus in a non lithium model?
    Tracing out the AC and DC circuits is pretty straight forward if you are doing mods.
    2025 360 CS
    Southern Maryland
  • rickpool
    rickpool Member Posts: 20
    @Yoshi_TAB, we meet again!  You and your posts were very helpful when I upgraded my 320 batteries, but I just bought a 360 Black Canyon with a 100ah BB Lithium standard.  Congrats on your 360 CS!  I saw you were upgrading the batteries… did you also install the MultiPlus Inverter/Charger?  If so, can you point me to any posts that show how to do this?  Thanks!
  • Yoshi_TAB
    edited September 2025
    Hi,
    Sorry for the slow response…I’m out traveling.  I have not installed  a Multiplus or inverter yet.  Going to work on it this winter.  I’m leaning toward just an inverter.  I do not want to give up the storage under the bed for the size of the multiplus and related parts.  I’m leaning just toward an inverter, maybe with a transfer switch like I had in my 320.
    We are out on a 5 week trip and I did install a larger 230 Ah battery.  We are not huge boon dockers  , maybe 25% of the time.  I’ve been having good luck with getting 50-55 amps of charging out of the WFCO.
    There is another 360 owner who I know had  the multiplus  installed   aftermarket I’m not sure if he did it himself  or had it done aftermarket .  I have seen pictures from him.  I’ve chatted with him quite a bit over FB messenger.  I need to get to my computer and will forward his pictures and contact info.  I’ve also seen pictures of the Nucamp Multiplus install which would help a lot .  Have you seen those?
    2025 360 CS
    Southern Maryland
  • Mountaintrails
    Mountaintrails Member Posts: 15
    I just brought a 2026 tab360 home, black canyon. Mine has the upgraded solar system but only the 100 amp hour battery.  I am leaning towards more battery storage. The Battleborn is an expensive battery for what you get. Is it worth it? That’s for the individual to decide. I am leaning towards taking Battleborn out. Installing a single 320ah battery. I don’t need the battery heater mode. I am pulling the battery and storing it inside my home in the winter. It’s inside the house of the trailer and that will not see low temps during normal operation. There will not be a need to change the charge controller for me anyway.
  • Zander360
    Zander360 Member Posts: 5
    2025 360 BC noob. It’s a bit tedious getting under the battery area (because of the reclining seat back) but I was looking at adding a LiTime 230Ah battery in parallel to the stock 100Ah battery. Not adding an inverter just yet and if I do, it will only be to power the outlet in the 360 kitchen area for a Blackstone grill. Gotta find the junction box for all the 120VAC wiring first.
  • Yoshi_TAB
    Hi,
    I have the 360CS where the OEM 100 ah battery is in the front.  I changed out to the 230 Ah LiTime battery and placed it  in the rear under the seat back, where it is placed for the non CS model.  I am very happy with the performance of the battery.  I consistently get 50 amps of charge out of the OEM WFCO charger.
    I cut the cover (over the entire rear area) into two sections.  One that would stay over the AC and a second section over the area where I relocated the battery.  Because you really do not need to go in there often, I thought it was fine.  Instead of screws, I placed velco around the perimeter to hold the covers in place, but in reality..I think it would be fine w/o screws or velcro.  The cover is recessed and not going any where.
    I'm also on the fence to add an inverter  or just use a Ecoflow or Jackery to power a few indoor kitchen items .  The only thing I want  to heat is  hot water in a kettle and run the microwave for very short periods of time.  Well within the the capability of those units .  I have an 2000W Ecoflow.  I installed an inverter and transfer switch when I had our 320 and although very convenient, I'm not sure all the work and expense is really needed for the little non shore power we need.
    All the AC circuits come out of the WFCO.  There is an extra slot you could use to place an outlet in the kitchen area.  I would guess the wattage of a Blackstone is in the same range of a hot water kettle (1500 or so) but would be run much longer for cooking than just heating water up.  Here are a few photos that might be helpful.
    On a side note, I've read it's not a good idea to mix different brands of LiPhos. batteries.  I ended up selling my 100 Ah BB.
    2025 360 CS
    Southern Maryland
  • rickpool
    Checking if anybody has any experience with the newer LiTime 320Ah Mini battery?  Am wanting to replace the BB10012h on my T@B 360 and this seems to be a very good option (as long as it fits).  I was happy with the LiTime 230Ah battery I previously installed on my old 320.  Any experience you can share would be greatly appreciated.
  • HandP
    HandP Member Posts: 1
    Just catching up on this set of comments. We have one of the first 360s to have been built - Black Canyon edition. Our first off grid experience last year was not good - the BB100Ah battery lasted only 26 hours in 90 degree heat with the trailer in mostly shade. And that's with the fridge on a low setting and the economy features enabled. Had to use the fridge as an icebox/cooler. Had to charge phones in the car. Needless to say, this is not what we expected. We seldom camp more than four-five days, but I wanted to be comfortable doing this without having to settle for sites with power. Here's what we did:
    1. Installed a 300 Ah Renogy Mini. It is a tight fit, but does go in. It was far cheaper to replace the BB than to add a second BB and only get 200Ah. Plus there is more air space for cooling. You will have to rearrange the hold down loops and get some new webbing. Only downside is that the battery does not have internal heating, but that is not an issue as we don't winter camp and I pull the battery at the end of the season. I was contemplating a separate hatch so I don't have to remove the whole seat every time - I was thinking hinge, but the Velcro idea above is great !
    2. Had the dealer retrofit the fridge cooling fan under warranty. Newer 360s have a small computer fan behind the fridge, wired to activate when the fridge is on. Before the fan was installed, the cabinet above the fridge got extremely hot, and we had to watch what food we stored in there. But the big issue was how hard the fridge had to run because the heat around the coils wasn't escaping. Fridge was running about 50% of the time, so that's 60 Ah in a 24 hour period.
    3. Installed a kill switch for the radio. The parasitic demand on the battery in our trailer was almost a full amp. Almost half of that was the radio (i.e. 12Ah in 24 hours). The TV, on the other hand, is almost nothing. You still have the CO2 detector and the power supply, but this was a significant reduction.
    4. Invested in a 220 watt Renogy external solar suitcase and MPPT controller. In full sun, this unit can crank out 8 or 9 amps and basically run the trailer by itself, even if the roof panels are in shade. I have 30' of cables to let me get to sunny spots on the campsite.
    5. Rewired the connections to the shunt. NuCamp tech says the only wire on the negative terminal of the battery should be the ground. My external solar bypassed the shunt, and there were some other issues. My Victron will now give an accurate reading on battery status.
    My first test this spring was a couple of 65 degree days with full sun in my driveway. The fridge on setting 2 ran two full days (along with the ceiling fan running most of the time drawing 1-2 amps), and I only used 34% of a fully charged battery. The roof panels were more effective than I have ever seen camping, so that helped, but I did not use the external solar suitcase. Much happier and more confident now. Looking forward to a full trial in the field to confirm.
  • SavvyNurseCamper
    SavvyNurseCamper Member Posts: 82
    Does the Tab 400 BlackCanyon Boondock have a fan behind it as well? Mine took 2 days to come to temp equivalent for food to stored in it? How do you know it's on? I noticed the vents above and below the refrigerator. I truly thought it was passive cooling and was going to put a computer fan in the area above the fridge to assist with the cooling and make it more efficient .
    I never even thought about the radio!!!! I would put a toggle on it and the power and turn it off when not being used.
