Anyone use snap pads with their stabilizer jacks? I noticed the 2025 models for the Tab 320s is not an option on their website when finding the correct size. Are the stabilizer jacks the the same size as the 2024s? Thanks!
I've been using them for my stabilizer plates and a round jack foot I have for about 5 years. They're kind of pricey but work great. Looking at their website, they have different sizes for 3 different years, 2018, 2021 and 2024 with different model shown for each. I'm thinking 2018 to 2020 used one size, 2021 thru 2023 used another and 2024 thru present used yet another. I'm sure if you contact them and give them the shape of the stabilizer pad (round or square) and the width, I'm sure they'd be able to tell you the right one to order. Good luck.
2018 TAB 320S Silver/Black w/100ah Lithium/Bluetti Solar Battery & Portable Solar Panels 2020 Honda Ridgeline RTL (AWD) Lunar Silver Metallic w/Bluetti Charger 1 North Texas - Retired Air Force/Corporate Trainer Trips - 48 Mileage - 63,452 "Our favorite trip will always be our next one"
Take care to check the clearance of the rear stabilizer struts. They tuck up close to the grey water drain pipe. In my 320s the Snap pads may not clear it. Unless they sized the rear one’s narrower.
2023 T@B 320s Boondock, 2013 Toyota Tacoma TRD 4x4 John, Northern California
MOUSE-KE-T@B
2022 nuCamp T@B 320 CS-S
Harvest, AL
https://www.vevor.com/trailer-jack-block-c_11891/rv-leveling-pads-5000-lbs-4-pcs-rubber-trailer-jack-pads-5-5-square-feet-p_010792219226
The 5.5" square fit our UT perfect.
