Snap Pads
Anyone use snap pads with their stabilizer jacks? I noticed the 2025 models for the Tab 320s is not an option on their website when finding the correct size. Are the stabilizer jacks the the same size as the 2024s? Thanks!
  • gkreitzburggkreitzburg Member Posts: 58
    I have them my 2023 t@b400. just measure the foot size - they have sizes to cover just about everything.
    2023 T@B 400 Boondock
  • rcarlson1957rcarlson1957 Member Posts: 254
    I've been using them for my stabilizer plates and a round jack foot I have for about 5 years. They're kind of pricey but work great. Looking at their website, they have different sizes for 3 different years, 2018, 2021 and 2024 with different model shown for each. I'm thinking 2018 to 2020 used one size, 2021 thru 2023 used another and 2024 thru present used yet another. I'm sure if you contact them and give them the shape of the stabilizer pad (round or square) and the width, I'm sure they'd be able to tell you the right one to order. Good luck.
    Trips - 48  Mileage - 63,452
  • MouseketabMouseketab Member Posts: 1,238
    Love my Snap Pads!
    Carol
    MOUSE-KE-T@B
    2022 nuCamp T@B 320 CS-S
    Harvest, AL
  • TourDeForthTourDeForth Member Posts: 125
    Take care to check the clearance of the rear stabilizer struts. They tuck up close to the grey water drain pipe. In my 320s the Snap pads may not clear it. Unless they sized the rear one’s narrower.
    John, Northern California
  • rfuss928rfuss928 Member Posts: 1,137
    edited November 28
    Vevor markets a very similar RV Leveling Pad in several sizes at very attractive pricing compared to "Snap Pads".
    https://www.vevor.com/trailer-jack-block-c_11891/rv-leveling-pads-5000-lbs-4-pcs-rubber-trailer-jack-pads-5-5-square-feet-p_010792219226
    The 5.5" square fit our UT perfect.
  • MickerlyMickerly Member Posts: 479
    Snap pads are a nice option. They are for larger trailers with a couple thousand pounds per stabilizer. It keeps the stabilizer from pushing into the summer asphalt by making a bigger foot. We have at best, 300 to 400 pounds per stabilizer.
    We camp mainly in State Parks. They have no benefit for us. The primary benefit for for our size trailers is in mud or soft sand. I went to their web site, the menu appears to have all the NuCamp trailers from 320 and up. If you can't find yours, give them a call directly. There are a limited number of sizes for the stabilizer feet.
    2018 320CS-S
    "Just Enough"
