I had Goodyear Endurance tires installed on my 2019 T@B400 in 2022. The date code on the tire indicates they were manufactured in 2022. I am diligent about maintaining the correct tire pressure. Recently I noticed cracks in the tread grooves on both tires. I returned them to where I bought them, America's Tire, and they offered me a credit on replacements, which I accepted. Much research tells me the Goodyear Endurance is a top rated, high quality tire. So what's up with these? I guesstimate I put 20-25,000 miles on them in the last three years. Remaining tread was 4/32". The spec says new they have 8/32".
As a side-note the technician showed me my right tire was wearing a little faster on the inside (3/32" tread depth) than the outside (5/32".)
We'll see.
Sold 2023 Tab 400
Sold 2018 T@B 320S
Southern California
Full-timer since 2019
Southern California
Sold 2023 Tab 400
Sold 2018 T@B 320S
@MOS2 I saw that pdf of pressure on a non-Goodyear site, couldn't find it via Goodyear's site. I see you have a 2025. What pressure is on your factory plate?
Southern California
Are your tires ST or LT?
Southern California
So the question is if the label will apply to ALL tires mounted on your rims, or just the OEM tires? I know in cars the door panel psi is the supposed correct psi despite brand?
Your tire has a load rating printed on it . All tires have this . Use the load rating and the GVW of your trailer , to come up with recommend tire pressure .
Use the chart .
Most trailer tire manufacturers are recommending maintaining the max cold pressure indicated on the tire side wall. This allows the tire to carry the max posted weight without any issues. If your trailer is lighter, you will get better gas milage and the tires will last longer; however, they will be harder than necessary for the trailer weight.
"Just Enough"
Trips - 48 Mileage - 63,452
TV 2025 Telluride X Type
Southern California
