Evidence of water intrusion
Hi all, We have a 2022 320S. I have noticed areas that appear, to me to be water intrusion, yet I need assistance identifying the source. I'll try to post pics.
  • another image
  • and last
  • The first shows delamination.The second is looking at the door jamb. and the third is inside the storage area under the bench.
    If anyone can point me in the correct area to look, i would greatly appreciate the help.
  • On my 2024 (since sold), we had a door that didn't seal properly-- though no water got in.  In your situation, with water getting past the door jam/interior threshold, I might begin to think that water is coming in around the wheel well and not from around the door.  I suppose it's possible for water to get in around the door and then make it back inside to that spot by the rug, but it would seem less likely.  There is a window there that could (theoretically) be leaking due to caulk issues, but it's hard to say.  I'm going with either the door seal or coming up around the wheel well during travel.
    Also, I'm assuming there have been no water balloon fights inside the camper.
  • Hi,
    A few common areas to check are (1) the interior wheel wells (2) The nautalis compartment seams to the inside  (you can  see where it's caulked) (3) the upper vent on the outside and it will drip down into the "electrical" wheel well area.
    Have you ever noticed water after it rains looking in all the compartments, behind drawers, etc.  I would  try hosing down the exterior one side at a time and and conduct an inspection.  Caulking can seperate after a few years in the environment a trailer  experiences bouncing down the road.  Hope you find it.
    2025 360 CS
    Southern Maryland
  • You might try a water test, something they occasionally resort to in the roofing biz. Have someone sit inside while you hose down the areas you suspect. Work from low to high as you soak the various exterior penetrations. Would be worth a shot.
  • rfuss928
    edited May 2025
    As these trailers roll and bounce down the road the body flexes and deforms slightly.  In our 2009 T@B CS and much less but also in our 2023 UT CSS this body motion causes the door seal to leak.  You can see the effect by pushing out on the latch side bottom corner of the door and noting how easy it is to get a quarter inch outward motion or more without much effort,  There is also evidence on the white door jambs on our UT near the lower hinge where dirty road water has gotten past the outer seal where the hinge plates crush the seal.
    Bottom line for us: We have a long established habit of putting a rolled up towel on the threshold so it rests against the door if there is any chance we will be towing in the rain.  There is a designated "door towel" that also works well as the dog towel when needed.  Not elegant but reasonably effective.
    The wet areas shown in the photos of the OP look very familiar from our experience.  The damage and stains are worse nearest the door on the front cabinet bottom and the front of the bench bottom gets wet and water gets under and wets the front of the wheel well seam.
    I have heard others at T@B gatherings speak of similar experience for years.
  • Thank you for contributing. We went out tonight and did the flashlight inspection. Light was visible at the lower corner of the door and the stripping doesn't go to the bottom. We also saw how the bottom of the door could easily bow out and allow water in while driving. No visible light in the wheel well from inside or outside. Since the door jamb area was the first noticeable, I would bet money on heavy downpours allowing water into the jam, and then the wood wicking it back to the end of the bench. Totally makes sense to me at least. I'll be searching for some weather stripping to place at the bottom of the door and then conduct a hose test. The door towel is also a good tip. Thank you all.
  • @helens Those doors leave a lot to be desired.  They are hard to fully close, and ours was warped in a way that it left the gap at the bottom I mentioned previously.  The fix at Nucamp is typically just bending the door to try and make it close tightly all around.  I did a bit of this on our camper and adjusted the hinges to try and get the best fit possible.  Was never perfect (because it's not a great door), but it helped.  I didn't have water coming in, but it bothered me to see light coming in around a fully closed door on an expensive new camper.
    Nucamp uses 3M 08008 (door gasket sealant) around the doors-- it's the goopy black stuff you see gooped in the corners.  Looking at your picture-- it looks like you might need a bit at the corner.  Warning though-- that stuff is the devil to work with, so be prepared for some cleanup.  It works great though and sets up quickly (I practiced with some scrap gasket in my garage first).  Also, they use Geocell Proflex most other places (clear caulk).  I think I got this stuff from an RV dealer.
  • As @rfuss928 mentioned these doors are prone to leakage while going down the road. Our previous '21 Tab 320 leaked and I took the entire door apart to dry it out and reaseal everything. Long story short, I was able to minimize the leakage but still had some. Towel in front of the door when we are expecting rain, even now in our '23 Tab 400 as it also leaks.
  • Nanabirdie
    edited July 2025
    @helens This is SO helpful, as I have a more advanced issue in exactly the same locations. A previous post of photos prompted a discussion about sealing maintenance of the wheel wells, but I am really hoping that the issue is truly coming from the door area which seems to be an easier fix. I’m wondering how difficult it is to disassemble the door….not likely I can tackle that myself, but I do need to find someone who can.
  • @Helens. Sure enough - I can see light under that door where it doesn’t quite close tightly. I hope you were able to resolve your issue…now I’m wondering if there’s a way to easily repair the wood laminate that’s peeling away on the inside wood panel by the door….yours appears to not be that far gone.
  • On a trip this Spring, after 7 hours driving through the rain the door towel was soaked beyond capacity.  Something needed to be done.
    I've considered a dead bolt of some type in the bottom corner to tie the door to the frame and prevent the seal separation during travel.  My quick test of this idea is a simple "Z" shaped clip screwed in the frame channel and pressing against the bottom corner of the door.  I flip it rearward when parked to keep track of it.  The red rubber cap protects the door finish.
    It certainly prevents the seal separation discussed above.  So far it is untested on the road because of good weather conditions while traveling.  If it solves the leaking issue I'll consider a nice dead bolt installation.
  • Hi all. I thought I would update this post. I live in N. Florida. The original owners also lived in this state. We've had cold temps this winter and ran the Alde in the camper on a couple of nights that were really cold(20's) and I discovered what I think is another main cause of this. When I checked the camper the following day, I found a puddle of water on the floor under the fan. Looking up, the cover was soaking wet from condensation. I also found water puddled in the doorway on the metal in the entry.  Since we weren't staying in the camper, I didn't vent any windows or fan. I didn't think it was needed. I was wrong.
    I am posting this as I live in an area with very high humidity. Even though I have a large Damp Rid container in the camper, these puddles still developed and totally contribute, IMHO, to the situation I have along with the weatherstripping and the door bowing during travel.
    My solution to keep the water away from the wood in the door frame is going to be to cut to size some pvc baseboard that I have, and seal it with caulk to keep the moisture from having access to the wood. I hope this will prevet the wicking from happening.
    As for the laminate, the only possibily I can think of is cutting a small piece of it(a vertical slash with a razor blade) to gain access under where it has raised up and then use something like Mod Podge to readhere it to the wood.
    If anyone has any other solution, please post.
    Also, does anyone know it the Alde gives of moisture while running?
