Ok, so the recommendation is to change fluid every 2 yrs because fluid looses anti corrosive properties. Does this mean Aldi fluid has a shelf life? Or does it loose those properties because of use. Can I use an open bottle of fluid that is over 2 yrs old?
2017 T@B 320S, 2023 Nissan Frontier, Parker, CO
0 ·
TV 2025 Telluride X Type
2020 Tacoma TRD Off-Road
2020 Audi SQ5
"I’ve read (or skimmed) most everything I could find on changing glycol in the T@B and see a mix of great DIY ideas, high costs from dealers and lot of hesitancy to dive in and try a DIY solution. Throw on top of that the unknowns about the need to switch to the new Rhomar fluid and it can cause analysis paralysis or just plain denial of the need to do anything – at least it did for me.
After getting through the denial phase and considering the uncertainty of the need to do a complete flush and switch to a new fluid, I thought I could easily handle a gravity drain of the system through the drain plug, and a refill of the system. I wondered, however, just how effective this would be. To figure this out, I drained what fluid I could from the system via the rear drain -- managing to remove 6.5 quarts of glycol (2019 T@B 400). Using a total capacity guestimate of 15 quarts, I calculated that each refill done in this manner would leave 57% of whatever fluid was in the system to begin with and add 43% new fluid each time. Assuming an exchange of this type each year and starting with 2-year-old fluid, the average age of the fluid just prior to the yearly exchange starts at 2.0 years (prior to initial exchange) and slowly rises to and average age of 2.3 years prior to the 10th annual exchange.
I’m not certain that the average age of the fluid is a precise indicator of its quality, but the calculations gave me the confidence that I could do a simple drain and refill each year without much risk of damage to the system. All this, of course, pending any new info on why Alde is recommending a new type of fluid, and pending my need to tinker with pumps, shop vacs, low-point drains and all the other great ideas that are posted in this forum.
For me the partial exchange approach is at minimum a short-term solution that takes little skill or time, and the only cost is the fluid itself. I’d love to hear any thoughts, especially on the assumption that the average age of the fluid is a reasonable indicator of quality."
In my 2017, I found it very difficult to perform the Tab Yoga needed to work in the very limited space where the Alde expansion tank is. I decided to use the process described in "Appendix A" of the DIY Glycol exchange file. I simply disconnected the hose where the non return valve exists next to the Auto Air Bleed valve. In about a minute, I was able to drain all of the glycol from that point, through the glycol loop, and back to the expansion tank and out to the open drain. Unfortunately, I did not measure how much I took out of the trailer. There was probably some glycol inside the Alde unit itself. With the glycol drained this way, when I took the convectors out to clean the corrosion, I found nothing but drips from the hoses and convectors. I'm reasonably sure I removed at least 70 percent of the glycol in my system with this method. When I do it again in the spring, I will be more careful with making some good measurements.
We have also continued to learn the real reason for the glycol corrosion, which Mark's video describes. Poor clamping, poorly fitted hoses, and unprotected stub ends were the real culprits.
Arguing against that a lot is the the testimony above.... (1)Alde fluid is pretty stable and does not have a short term shelf life. (2) There is no reported corrosion of the Alde system outside of the ends of the convectors and that is most probably due to improperly clamped hoses.
So, if you have a unit that is several years old and no corrosion issues at the convector ends you may not need to change the Alde fluid at all??
While that logic seems pretty sound, I think I will opt for a simple drain and refill every 2-4 years, out of an over abundance of caution.
P.S. I just had a complete fluid exchange done in the last 30 days and that's what got me thinking about all of this.
I've not seen verified testing to confirm that Mark's theory is correct, but there is logic to it. I believe that both things can be true. Glycol penetrating around the stub ends is causing corrosion and that a better formulated glycol product will reduce or eliminate that problem. Will the new Alde fluid be this product? For now, there's only anecdotal evidence one way or the other. Doing both, putting a second clamp right at the end of the convector and using the new glycol is probably the best advice.
of the radiators are going to get eaten away, regardless of the poor clamping, poor fitting hoses or whatever
type of heat transfer fluid is used.
I recently completely disassembled my Alde on our 2018 TAB 320 Boondock, replaced all the corroded
fittings with 316 SS bits, shortened the radiators by cutting back the corroded stubs, painted all the surfaces
with POR15 (DMI based) and replaced the heat transfer fluid with G12 evo..as I think that if there was ever a
problem with the fresh H20/glycol interface the pressurized system would go into the unpressurized side.
Any comments are appreciated, Cheers.
I found a technical description and safety profile of one brand's version.
It seems to be impressively non-corrosive for the Alde and radiator. If you had a leak in the heat exchanger while the fresh water supply was not pressurized (i.e., most of the time) there would be some contamination of the fresh water. Perhaps not too much for you?
1. Documented Toxic Exposure Levels
For a 170 lb (77 kg) adult, the "danger zones" for ethylene glycol (the toxic one) are surprisingly small:
Regardless, the pressure argument is probably academic. In a depressuzed state--which is most of the time when the unit and the FW supply are both off--any breach between the glycol and HW chambers is bound to result in some comingling of fluids.
