How long does a Tab 400 battery live and how do you know if it is dead? Mine does not charge up anymore but could that be a problem with the charging system it is it likely the battery? thanks
Before we can answer this, or any question, we need to know what year your trailer is.
For the 400, there are many different battery setups: one giant 225 ah deep cycle lead acid. Two dual 6V lead acid batteries. Lithium battery setups started a couple of years ago, and there are many combos of batteries and inverters, etc.
If: you have a trailer that is about 5 years old or so, and it still has one of the "AGM" or "lead acid" batteries, even if they have been perfectly taken care of, they may be reaching the end of their service life.
"Not charging up any more" or hot holding a charge is a perfect example of a battery that may not be well taken care of, or just reaching the "end of life" that all lead acid batteries reach.
So, tell us what year the trailer is, and which battery you have. Tell us if you are using a multimeter or the Victron app to help get a status of the battery. And, get down there in the battery compartment and see what you have in there. A picture would be great.
There are many good upgrades for the original AGM's if that is what you have.
Thanks! My rig is a 2021. We’ve kept it plugged it all the time except a few camping trips w/o hookups. I’ll get into the battery compartment next and see what type they are.
Great! A 2021 would have the "dual 6V 225 amp hour" lead acid batteries, if they have not be changed out since 2021.
A lithium battery can be a straight replacement. We would have to check the version of your WFCO converter. Earlier "non-lithium" converters could charge a lithium, but "only" to about 85 percent. Newer versions from around your model year might have had a WFCO with a "switch" that told the charger to use lithium charging profiles. Later WFCO's had "auto detect" chargers that were supposed to detect lithium batteries.
So, have a look inside your WFCO and check the model number. It will be something like "8735" and a designation of LiS for the switch model, or AD for the auto detect. (A 2021 "might" have the LiS version).
Even with a "non-lithium" converter, owners have used the solar charging to properly charge the battery, or a stand alone lithium charger to do the job when on shore power.
There is a ton of info about that when you start to look more closely at this.
Here is a picture of the label inside your converter. This one has the "AD" designation, which is the "auto detect" model. The other version is the LiS, or lithium switch model. Your 2021 may not have either designation, which would mean it is a "non-lithium" sort of converter. The "non-lithium" would still charge the lithium battery, but only about 85 percent.
I have a 2025 tab 400. 620 watts solar. 1BB 100 amp battery. Battery heater switch. 1200 watt power inverter. My question is, if I install 230 amp li-time litium, do I need to defeat battery heater connections ? Did not find litime with battery heater function. Could tape over switch in cubby and isolate connections by taping to avoid shorting anything. Thanks.
The Battleborn heater is built right into the battery. The cable coming from the battery is simply wired to the switch to turn them on. So, your idea of simply disabling the switch or terminating the wire would work just fine.
As pthomas said above, you may be able to just use your old converter. I have an older converter in my 2021 Tab 400, and when the AGMs died, I replaced with lithium. While I can only charge to ~85%, since I have solar, the solar can 'top up' the battery all the way to 100% from there, so I never felt the need to go upgrade the converter.
In our 2019 it is under the closet, as we have the small fridge.
