What is the baseline power draw, and how can it be reduced?
2»
  • pthomas745pthomas745 Administrator, Moderator Posts: 4,438
    This is all interesting, and the sneaky little light in the Alde control panel power button strikes again!  This has happened before.
    Do you have battery power in the trailer?  Any red lights next to the fuses when the battery switch is on?
    No shore power to the trailer could be: a tripped breaker from your garage circuit.  A tripped 30 amp breaker inside the WFCO.  A tripped GFCI circuit.  If you turn the battery switch off, do the lights in the trailer still work if you try them?
    In any case, you did some nice police work here.
  • ckjsckjs Member Posts: 128
    JHornby said:...
    6.  Converter Power.  No idea what this is, but when I pulled that fuse the entire amp draw went to zero.  I assume this is some sort of master fuse that rules them all?
    I always thought that the 30A Converter Power fuse covered the charger's output from the converter to the batteries and the other 12V load circuit.
    If the batteries were not present, then all the 12V circuits would be dead. Does that explain things?
