Today I will mount a Victron 100/20 controller in the space under the port side seat, connecting existing wiring to solar panel and battery. I’m working out how to wire up the Victron SmartShunt that will arrive in a few days. Through meter testing, it looks like the wires that come from the solar controller go straight to the battery. So my plan is to wire the shunt into the negative side battery wire coming from the controller, and then mount the shunt beside the solar controller. Does anyone see any issue with that plan? Seems like it would be a clean install with no weather issues.
of the shunt to the battery negative terminal. It probably makes more sense to late the shunt closer to the battery minus side.
John, Northern California
just insert them into the little holes. They go right in up to the trimmed insulator. Pull firmly once screwed down to confirm tight joint. Clean install.
Do you guys know what gauge wire I will need from the shunt to neg battery terminal? I thought I’d make that up in advance.
Volvo XC-40
SF Bay Area, California
St Catharines, ON
