I modified the crank on the trailer jack, now pointing to the rear, so the handle would clear my F-150 tailgate while the trailer was attached. What I did not check was the clearance for removing the spare tire. I have a 320S Boondock with the spare mounted on the front of the tub. I am getting new tires so I tried to remove the spare tire. The problem is insufficient clearance to remove the spare with the handle pointing to the rear. I'm glad I discovered this in the garage and not out in the boonies somewhere or along a busy interstate! I've been running this way for a couple of years and thankfully never had a flat.
Now I need to rethink things and find a way to have clearance for the tailgate while still allowing access to the spare. Just thought I'd give a heads up for anyone who might have made a similar mod to the jack handle and not realized the clearance issue.
2025 KZ Sportsmen 130RD
2023 Ford Maverick XLT
The Finger Lakes of New York
John, Northern California
https://tab-rv.vanillacommunity.com/discussion/1395/power-tongue-jack-cost-less-than-a-buck/p1
