Looking for the SmartShunt 2024 T@B 400
Hello, I figured the smartshunt would be near the battery but it’s not there. Does anyone know where I can find it?
I’m troubleshooting a scholar issue but can’t connect to victron because I forgot my pin.
2024 T@B 400 Boondock
    MuttonChops Member Posts: 2,085
    @floridaman if you intended to include a picture/image; there was an upload error - - nothing is displayed
    I cannot directly answer your question.
    In general on TAB 400 with a factory installed Shunt:
    -  1  -  There is one large wire from the battery negative terminal.
    -  2  -  That wire leads directly to the shunt,
    -  3  -   The other side of the shunt is wired to the Negative Side of a 12VDC Distribution block
                 { a two terminal small item with several Positive and Negative connections. }
  • floridaman
    floridaman Member Posts: 20
  • floridaman
    Sorry about the lack of picture. But here she is.
  • floridaman
    Thanks for the diagram @MuttonChops. I’ll try to trace the leads from the battery and find the shunt.
    qhumberd Administrator, Moderator Posts: 914
    If its like mine, the actual shunt is circled in red above. The "Smart Shunt" Victron box I have seen I don't see here, but is that not a wireless Bluetooth connection to the shunt? You can clearly see the large black cable as the final connection to the battery, where it should be.
  • rfuss928
    rfuss928 Member Posts: 1,197
    edited February 12
    floridaman  The shunt is just to the left of the battery mounted to the plywood partition in your picture..
    @floridaman by now you have found the Shunt Location . . .
    Here are the other items in your Battery Box Area:
  • floridaman
    Oh interesting. I was looking for the victron device so I could read the PUK code because I forgot the password. I guess that’s not it?
    floridaman said:
    . . . was looking for the victron device so I could read the PUK code because I forgot the password. I guess that’s not it?
    The SHUNT shown in the above picture and a few of the earlier replies is a Victron SmartShunt.
    The PUK Code Label is located on the unit End, most likely the end facing the trailer front.
    Reference Video
  • floridaman
    Ah okay thank you!
