Looking for the SmartShunt 2024 T@B 400
floridaman
Member Posts: 20
Hello, I figured the smartshunt would be near the battery but it’s not there. Does anyone know where I can find it?
I’m troubleshooting a scholar issue but can’t connect to victron because I forgot my pin.
2024 T@B 400 Boondock
@floridaman if you intended to include a picture/image; there was an upload error - - nothing is displayed
I cannot directly answer your question.
In general on TAB 400 with a factory installed Shunt:
- 1 - There is one large wire from the battery negative terminal.
- 2 - That wire leads directly to the shunt,
- 3 - The other side of the shunt is wired to the Negative Side of a 12VDC Distribution block
{ a two terminal small item with several Positive and Negative connections. }
'18 320 S, pitched axle, 3020HE; PNW basedTV: '17 Colorado V6 Z71 4x4, Tow Package, GM Brake Controller
Adventures: 58 Nights: 405 Towing Miles 50,180 -
Sorry about the lack of picture. But here she is.2024 T@B 400 Boondock
Thanks for the diagram @MuttonChops. I’ll try to trace the leads from the battery and find the shunt.2024 T@B 400 Boondock
If its like mine, the actual shunt is circled in red above. The "Smart Shunt" Victron box I have seen I don't see here, but is that not a wireless Bluetooth connection to the shunt? You can clearly see the large black cable as the final connection to the battery, where it should be.2019 T@B400 Boondock Lite "Todd"2016 Toyota Tundra 5.7 Crew Cab -
floridaman The shunt is just to the left of the battery mounted to the plywood partition in your picture..
@floridaman by now you have found the Shunt Location . . .
Here are the other items in your Battery Box Area:
Oh interesting. I was looking for the victron device so I could read the PUK code because I forgot the password. I guess that’s not it?2024 T@B 400 Boondock
floridaman said:
. . . was looking for the victron device so I could read the PUK code because I forgot the password. I guess that’s not it?
The SHUNT shown in the above picture and a few of the earlier replies is a Victron SmartShunt.
The PUK Code Label is located on the unit End, most likely the end facing the trailer front.
Reference Video
- 920 Introductions
- 74 Teardrop Groups & Links
- 915 Tips & Tricks
