We have a 2026 Haven with Goodyear Endurance ST225/75R15. I want to replace these with a slightly larger tire and am leaning towards the Kenda ST235/75R15 Radial Off-Road Trailer Tire - Load Range D. According to nucamp,
"The minimum clearance from the center of the hub with the wheel/tire package as equipped is ~17", and the Goodyear Endurance tire (ST225/75R15) is ~28 1/4" in diameter. We have not gone about the process of sizing out how much bigger you can actually go, but there's a sufficient amount of room to go bigger."
The Kendra should give us a bit more under carriage clearance and a better look.
I'm no tire expert so I have two questions; first the Kendra tire in general. Does anyone have experience with it on their nucamp trailers. Second, I'm sort of confident the Kendras will fit but again, I'm not a tire expert so wanted to ask "will they fit"?
2025 Haven 220
2020 Ford F-150 XLT (V-8)
Niceville, Florida
I don’t have any experience with Kenda (Kendra?) tires. I do know there are myriad conversations on this app and others about getting rid of “China bombs” and installing Goodyear Endurance tires, specifically.
2018 T@b 400
2019 Ram 1500 crew cab / 5.7 V8
Unfortunately, Goodyear does not offer a tire in the ST235/75R15 size.
2025 KZ Sportsmen 130RD
2023 Ford Maverick XLT
The Finger Lakes of New York
Thank you. While I love the Haven, I'm not happy with the low squat look. I knew there was "growth" in the wheel well but also learned if I wanted a bigger tire, say a 16, I would also need a larger rim. So, I went back to the original size on our 400. From your note, it appears I would not gain much by going with the 235/75-R15. Thank you, you saved me a bit of money. On a different Haven topic, I learned that the iron triangles on the back of the Haven are bolted on. I've rubbed them a few times are relatively low grades so I personally think they are too long. I think I'm going to remove them and have a local welder shorted them a bit. I will need to measure so I don't cut them too short and they continue to function as intended.
