Upgrading tires on the 2026 Haven
Haven 220
2026 Ford F150 Tremor 5.0
Niceville, Florida
@Blueespy
I don’t have any experience with Kenda (Kendra?) tires. I do know there are myriad conversations on this app and others about getting rid of “China bombs” and installing Goodyear Endurance tires, specifically.I made that switch about two years ago and have to admit it made me less anxious while traveling.I would recommend searching out some of those threads here on the app.Doesn’t Goodyear make a tire in the larger size you’re looking for?gande
2018 T@b 400
2019 Ram 1500 crew cab / 5.7 V80 -
gande said:@Blueespy
Unfortunately, Goodyear does not offer a tire in the ST235/75R15 size.Haven 220
Niceville, Florida
235/75-R15 tires are 0.59 inches (15 mm) larger in diameter than 225/75-R15 tires so not much difference for the additional 1/4" clearance you'd get. Main difference is width and tread. Non-traction tires so width won't make much of a difference either. Not worth the change for size. Only difference is if you think a off road tire would be more useful or just look nicer. Not needed for campgrounds. The Kenda tires are wider. Make sure you have clearance width wise. They will also be less efficient gas milage wise.2021 T@B 320 S Boondock
2025 KZ Sportsmen 130RD
2025 Ford Ranger
SLJ said:235/75-R15 tires are 0.59 inches (15 mm) larger in diameter than 225/75-R15 tires so not much difference for the additional 1/4" clearance you'd get. Main difference is width and tread. Non-traction tires so width won't make much of a difference either. Not worth the change for size. Only difference is if you think a off road tire would be more useful or just look nicer. Not needed for campgrounds. The Kenda tires are wider. Make sure you have clearance width wise. They will also be less efficient gas milage wise.
Thank you. While I love the Haven, I'm not happy with the low squat look. I knew there was "growth" in the wheel well but also learned if I wanted a bigger tire, say a 16, I would also need a larger rim. So, I went back to the original size on our 400. From your note, it appears I would not gain much by going with the 235/75-R15. Thank you, you saved me a bit of money. On a different Haven topic, I learned that the iron triangles on the back of the Haven are bolted on. I've rubbed them a few times are relatively low grades so I personally think they are too long. I think I'm going to remove them and have a local welder shorted them a bit. I will need to measure so I don't cut them too short and they continue to function as intended.Haven 220
Niceville, Florida
Maybe it's time for a Haven Boondock!0
We’ve purchased a 2025 Haven, and the dealer is adding a 3” riser kit to the axel for $600. We added that mad to our previous camper with the angled skid bars and that solved our low clearance issues. Another option for your consideration.1
jayhawk78 said:We’ve purchased a 2025 Haven, and the dealer is adding a 3” riser kit to the axel for $600. We added that mad to our previous camper with the angled skid bars and that solved our low clearance issues. Another option for your consideration.
Could you share any specifics as to what model etc. about the 3" riser kit?Haven 220
Niceville, Florida
We had our Haven at the factory in May for some warranty work but before we arrived, we had been discussing the installation of a pitch axle. nucamp advised they had done some testing of a pitch axle and were happy with the results to the point they could offer a replacement. It looks much better and the clearance meets our needs. Talking with nucamp, I think I heard them say they would in the future offer two options for axle upgrades…either a 10 or 20 degree pitch. The current axles are 0 pitch. We drove about 800 miles with the new axle and other than having to adjust our hitch height, no changes were needed. In fact, I think with the new axle, the Haven rides better.
Haven 220
Niceville, Florida
- 120 Dutchman and Vintage TaB Archives
- 920 Introductions
- 75 Teardrop Groups & Links
- 916 Tips & Tricks
- 54 üCamp Rally - News & Information
