removing latch from T@B400 window (not from window frame)
I'd like to remove the window latch from the windows on my 400. I see screws to loosen but I am concerned that the plastic part the screw goes into, the part that is inside the two panes will fall away when I take both screws out. Does anyone have experience removing the latch screws?
2019 T@B400
Southern California
Full-timer since 2019
  • I have exactly the same question. I want to take the latch off to put some graphite lubricant into it
    2018 T@B 400 "Fara"
    TV = 2021 Ford Explorer Sport "Misty"
    Other camper - 1971 Mitchell Truck Camper on 1970 F250 Camper Special "The Turtle"
  • @jimcenname did you ever get an answer or figure out what might happen?
    We have a window latch (lockable style), same as you picture above, where the red lock button is broken. The red button pops out further than the others which allows the handle to rotate. It other words, it does not have a lock mode.
    If the latch can be removed, are new ones available for purchase? I scanned the nuCamp site store, but didn't see one.
  • I have not learned how to remove the latch.
    2019 T@B400
    Southern California
  • Ok, thanks for the quick response, Jim.
  • I have a sticky latch too. If you end up asking NuCamp, I’d be interested in the answer
    2024 T@b 400
    2019 Lexus GX 460
  • I emailed Creed at nuCamp and will pass along his response.
  • rfuss928
    edited April 27
    SWAG:
    Remove one screw
    Loosen second screw enough to rotate latch
    Place first screw through window into anchor plate.
    Remove second screw...
    Reverse to re-install.
    Either screw should grip the plate enough to rotate it into position as needed.
  • @rfuss928, funny, I actually ran that scenario through my head too, but I need reassurance that it will work though, before trying it.
    I haven't had to use it on the window latch but have had several similar situations where that was the required procedure. Usually not in transparent material which added another level of challenge. I think you'll be all set for the latch removal..
  • scott14
    edited April 27
    Jordan Brown, from nuCamp responded to my question. He said, "Typically the backer plate is glued in there. It shouldn't move unless the glue has come loose or something."
    He also mentioned that we will have to go through a dealer to order a replacement latch, as they are not available on the nuCamp small parts store website.
  • scott14
    edited May 27
    Update: I ordered the new latch through my local dealer and had it direct shipped to me. The total cost was around $32 (includes shipping). I was able to successfully swap out the old latch with the new one, using the method described above by @rfuss928. The piece in between the panes remained attached and in-place. The entire project took about 5 minutes.
