removing latch from T@B400 window (not from window frame)
Southern California
Full-timer since 2019
I have exactly the same question. I want to take the latch off to put some graphite lubricant into it2018 T@B 400 "Fara"
TV = 2021 Ford Explorer Sport "Misty"
Other camper - 1971 Mitchell Truck Camper on 1970 F250 Camper Special "The Turtle"0 -
@jimcenname did you ever get an answer or figure out what might happen?We have a window latch (lockable style), same as you picture above, where the red lock button is broken. The red button pops out further than the others which allows the handle to rotate. It other words, it does not have a lock mode.If the latch can be removed, are new ones available for purchase? I scanned the nuCamp site store, but didn't see one.
Scott / 2019 T@B 400 / 2015 Chevrolet Tahoe LTZ / Northern Illinois
I have not learned how to remove the latch.2019 T@B400
Southern California
Full-timer since 20190 -
Ok, thanks for the quick response, Jim.
I have a sticky latch too. If you end up asking NuCamp, I’d be interested in the answer
2024 T@b 400
2019 Lexus GX 4600 -
I emailed Creed at nuCamp and will pass along his response.
SWAG:
Remove one screw
Loosen second screw enough to rotate latch
Place first screw through window into anchor plate.
Remove second screw...
Reverse to re-install.
Either screw should grip the plate enough to rotate it into position as needed.
2 -
I haven't had to use it on the window latch but have had several similar situations where that was the required procedure. Usually not in transparent material which added another level of challenge. I think you'll be all set for the latch removal..scott14 said:@rfuss928, funny, I actually ran that scenario through my head too, but I need reassurance that it will work though, before trying it.
Jordan Brown, from nuCamp responded to my question. He said, "Typically the backer plate is glued in there. It shouldn't move unless the glue has come loose or something."
He also mentioned that we will have to go through a dealer to order a replacement latch, as they are not available on the nuCamp small parts store website.Scott / 2019 T@B 400 / 2015 Chevrolet Tahoe LTZ / Northern Illinois
2 -
Update: I ordered the new latch through my local dealer and had it direct shipped to me. The total cost was around $32 (includes shipping). I was able to successfully swap out the old latch with the new one, using the method described above by @rfuss928. The piece in between the panes remained attached and in-place. The entire project took about 5 minutes.
3
- 143 Events & News
- 923 Introductions
- 76 Teardrop Groups & Links
- 918 Tips & Tricks
