External Solar Port on T@B 360
Hi, We have a '25 360CS and it was not connected to the solar controller. It was connected directly to the battery. I did a point-to-point wire verification, and it was not, at least in ours.2025 360 CS
Southern Maryland1 -
Grab a multimeter and see what you get. The voltage from the meter should be basically the same as the voltage from the Victron app for battery voltage. I don't think that any of the SAE ports were ever wired any other place than to the battery on any trailer, at least trailers from the factory.
Towed by 2014 Touareg TDi2 -
I don't think you'll be able to get a firm answer from this forum. You need to check. Mine was not connected to anything. Just remove the square head screws and lift off the panel underneath the driver side bunk. It's pretty easy to trace where the two wires end up. The fact that they are not connected is not necessarily bad. You may not want to combine mismatched panels on one solar controller. Ideally the best results come when all panels on a shared controller are identical. The good news is you can get a very reliable and inexpensive solar controller for your suitcase panel, in fact it may come with one. Mine did not, but I located the second controller in the camper so that the voltage is not down converted until right before it's used, which I think is slightly more efficient. That second controller goes then through the smartshunt as well. (POS to positive battery or positive bus, and neg to the load side of the shunt). The suitcase controller is the black box in the upper right corner. I did add pos and neg bus bars to reduce stacking of connectors on the shunt and battery itself, but those are not strictly speaking necessary.
2 -
Thanks all. Would there be a meaningful benefit having both controllers the same brand (Victron) so that they can be managed together in a single app? Or is a cheap, portable controller sufficient?0
Great question. If you care about monitoring your production totals and history all in one place I suppose it would be useful. But if you have the portable wired through the shunt you can easily see if it's working and use that feedback to position the panel optimally. The suitcase panel is a backup / adjunct for us so I am fine with simple. If I really needed to know what it was producing I could do the math to compare the batteries state of charge gain with what the camper panels had produced.1
Just make sure the controller supports lithium batteries by the way. (Most of the new ones do)0
Using a Victron suitcase solar controller has the advantage of having the ability to network it with other Victron devices like your rooftop solar. When networked they optimize charging for efficiency and have all the battery/charging information available in one app.rickpool said:Would there be a meaningful benefit having both controllers the same brand (Victron) so that they can be managed together in a single app? Or is a cheap, portable controller sufficient?
The Victron devices network which assures that all the controllers are in the same charging mode regardless of the solar / shade of different systems. IMO the extra Victron solar controller was an easy choice.
My 120 watt back-up package.
nuCamp sizes the Victron solar controllers that they factory install to the wattage of the rooftop solar. In most cases, there will not be enough room (edit: capacity) left for an additional panel. Buying a suitcase panel without a controller and adding a separate Victron controller mounted close to the battery has the advantage of reducing the voltage drop that results from the long wire run between the panel and your trailer.rickpool said:I am trying to figure out whether the external solar port inside the Nautilus box (360 Black Canyon) connects to the Victron MPPT controller or directly to the battery?
edit to add that the designation, like 75/10 on the controller stands for 75 volts and 10 amps. Exceeding the voltage will damage the controller, so you would have to be careful not to exceed the maximum combined PV voltage from your rooftop and a secondary solar suitcase. If you were certain that this would not be the case, then you could use the factory controller for both. The drawback is that it would never provide more than 10 charging amps to your battery.regardless of the amperage coming from the panels.
The Zamp plug assumes you have a solar controller before the plug. I preferred to have my controller safe from the elements not loose on the ground. Also I wanted the same victron so I could see the status via bluetooth and form a network. I added a second 100/30 victron MPPT next to the existing roof top solar controller. If you wanted to do something similiar you could redirect the Zamp plug to go to this new controller or do what I did and add another MC4 port on the other side of the Nautilus. This involved drilling and sealing the MC4 port. I now use the Zamp plug just for my Victron battery charger0
I use my 12v SAE port as an easy battery connection more often than I use it for solar input. It is where we plug in our compressor cooler as well as a maintenance charger during storage.
I would not permanently install a solar controller in that line.
I understand the ease of using the existing factory SAE port for things other than solar, but for accessories adding an external cigarette lighter port is a more versatile solution and won't conflict with solar charging.
I have found those cigarette lighter connections to be very unreliable many times and avoid them if possible especially in higher current applications.AnOldUR said:I understand the ease of using the existing factory SAE port for things other than solar, but for accessories adding an external cigarette lighter port is a more versatile solution and won't conflict with solar charging.
In the first versions of the Tabs with the SAE port, many owners installed their solar controllers inside the front tub. The SAE port was rewired from the battery to the solar panel input on the controller, and a separate set of wires went from the controller to the battery. There are a couple of examples here, and another thread embedded in the comments has a couple more.In the "Anyone Carry A Spare Battery" thread, @rfuss928 showed how to set up the trailer's 7 pin plug to use as an "accessory". I've used mine to charge the trailer battery with solar, and to plug in my "spare" battery to run the trailer (with the battery switch off).I've run my trailer with a male to male 12V plug into the 12V ports, and it works, but I agree the ports are a bit shaky.
I agree @rfuss928. The point was that most of the accessories like your 12V cooler come with this type of connection. Personally, I've been switching everything over to Anderson PP15 connectors. I was even able to find a new wire for our 12V cooler that had the PP15 on the end commercially available.rfuss928 said:
What I was trying to say is that having your solar controller between the battery and external port has advantages and that it's easy to add a second port for accessories. I shouldn't have specifically said a cigarette lighter port. I'm not a fan of SAE port either.Stockton, New Jersey
Not sure I follow all the details of this discussion. I have an external suitcase type 80 watt solar panel that has a built in 10 amp PWM (whatever that is) that I plan to use as back up solar when we are camped in shade. I have the adapter that allows it to be plugged in to the external solar port inside the Nautilus on my 2026 Tab 360 cs. Is it as simple as plugging in to charge my batteries ( I have 2 100 ah lithiums with the victron controller on board)? Help out a non tech person if you can. Thanks!
Possibly. 😉 Basically yes, I assume nucamp is still using SAE connectors like they have done for years. The potential problem with these is that there is no defined "polarity", meaning the exposed pin can be negative or positive depending on which end of the connection you look at. If the charge controller doesn't power up or shows an error you need to reverse the "polarity" aka switch the pins either via wiring or there are little gizmos called "SAE polarity adapters".
The SAE connector on our trailers (in 99 percent of the installs) are set up so that the "positive" output from your solar controller is carefully "inside the plastic" of the cable that connects to the port. It is not "reversed" or backwards in any way. This thought of "reverse polarity" is now so entrenched in every conversation of the port that I just beat my head against the wall trying to explain it. Here is a photo of an SAE port wired in a 320 with the "positive" wire from the battery on the top…in this port, the positive wire from the controller should be wired to the part of the cable that is "inside the plastic". If you check with a multimeter, and see exactly how the port is set up, you can wire the cable from the controller appropriately and skip the "adapters". I have SAE connectors on all of my solar setups, and since I've always made sure on the proper "polarity" of every cable, I do not have any "adapters".
So, don't listen to me, don't listen to anyone. Sort out how your SAE port is wired, and wire things accordingly. Get a multimeter, we can show you how to use it.
Your 80 amp hour panel with the 10 amp controller ( a PWM is simply a type of controller) will work just fine with your "port". The only downside is an 80 watt panel might only bring in 3 or 4 amps at the most, which is not really enough to charge your 200 amp hours of battery quickly. But, as an adjunct to your solar on the roof, it will help. The best part, though, is getting that panel and controller combo to work will give you some experience when you want to improve that setup.
Towed by 2014 Touareg TDi1 -
What @pthomas745 says is great advice. A couple other things to keep in mind: depending on previous set up, that SAE may not be connected to anything. OR it may be connected directly to the battery, as opposed to going thru the Victron Smartshunt. In this case it would add power, but that power won't show up on your app and will eventually make the state if charge inaccurate. So, just have a look at the wiring for the onboard solar and mimic that. (I use a 100w panel and it often adds quite a lot of placed strategically.)
- 143 Events & News
- 922 Introductions
- 75 Teardrop Groups & Links
- 918 Tips & Tricks
