The dealer put in a brand new (I hope) Group 29 when I picked it up on Aug 20. It has been just 2 weeks...I thought it wouldn't be that low and since using the cut-off there should be no phantom draw. I'd have to get someone to take it out for me due to the weight but if it is bad the dealer better cough up another one! I was just under the assumption that 2 weeks with no drain would have kept it at least at a higher level. Maybe tomorrow I'll hook up to my truck and run it for a bit - would that be a good thing...or just leave it on the trickle charger? I left it on as the storage lot owners said it'd be fine (no one will mess with it). Just hope it doesn't rain this evening.jkjenn said:I believe your battery charge looses juice by just sitting. How long did it sit before you charged? A few days, a month? You might want to take it out and take it to AutoZone to have them test it for you.
mickietucs said:I'll check it first thing tomorrow - I left the trickle on it. I know it takes a long time on a trickle charger but tomorrow's numbers will determine if I'll somehow get it to Auto Zone to test it. Also there's a 20 amp fuse in it and Beth and others said I should put in a 30 amp - correct?
Thanks Verna - why the heck do the dealers put in a 20 amp? Jeez! Also, since this is in a storage lot and I no access to 110 (to say plug in a typical Battery Tender) is there any other means other than solar to charge (haven't swung for a generator yet)? Right now I only have a 6 amp solar trickle charger. A Battery Tender has to be plugged into 110 - yes?Verna said:mickietucs said:I'll check it first thing tomorrow - I left the trickle on it. I know it takes a long time on a trickle charger but tomorrow's numbers will determine if I'll somehow get it to Auto Zone to test it. Also there's a 20 amp fuse in it and Beth and others said I should put in a 30 amp - correct?
Correct, it should be a 30 amp fuse on the battery. When I remove it, I put it in a small ziplock bag and put it on top of the middle of the battery so I know where it is and know it shouldn't move.
Good to know that battery is charging (I purposely closed the cutoff switch thinking that would be better as there'd be no draw). They now make a Battery Tender Solar charger which looked nice - and thinking the 15 watt would do a better job than the 6w I have on there now. Hoping I see a higher reading tomorrow. Thanks!PXLated said:Yes, the traditional battery charger/tender has to be plugged in to 110.
Typically, the battery tender is clipped directly to the battery terminals so yes, it would charge the battery no matter the position of the cutoff switch. But if the switch was on, the T@B would be draining a certain amount from what the tender was putting in.
Michelle, check to make sure the battery cut off switch is indeed wired correctly. If it is "off" there should be no power to anything 12V (lights, sound system, TV). If it is "on" the lights, sound system, TV should work. If reversed, that would be an explanation of why the battery was drained.
As far as the 20 amp fuse, it could be human error or lack of knowledge. Contact the dealer in a learning manner and suggest they may have put the 20 amp fuse at the battery in error, instead of the 30 amp fuse. You may need the dealer further down the road and you don't want to alienate them.
ChanW - I will do what you suggested (I had purchased a voltage meter and this will be the first time using it - hope I get it right!). Yea, I have to remember that wimpy trickle charger I have is really is only that - a trickle to an already full battery. Luckily I'm in Tucson and the monsoons aren't too prevalent right now so we're back to having full sun - hoping all day yesterday and all day today may help. But if need be, I'll get someone to help me haul it out of the box and get it somewhere to provide a good charge. Where does one go to get a charge with a 120v charger (Auto Zone)? Can I buy that type of charger (are they expensive)?ChanW said:Michelle,
You might want to check the voltage right at the battery terminals to get an accurate idea of what's in the battery, then you won't have any voltage drop to contend with in your figuring.
The 6A or 15A solar charger is probably rated at full sun with a voltage/current limiter of some kind. A trickle charge usually only puts out @ 2A max, and if your solar charger is limited to that 2A output, and only during the day when the sun is good, it could take a few sunny days to restore a discharged battery. A trickle charger is really intended to simply maintain an already fully charged battery.
It might be smart to take it out as Jenn suggested, to get a full charge with a 120V charger, and then keep the trickle charger on it any time it sits for a few weeks.
Thanks Jenn - So in essence I'm doing the battery load test. One Youtube video from some rv place the guy turned the dial to the first setting on the right (DCV) so that confused me. The DCV setting has the two lines above the V which I think measure the alternating and direct current. Do you know why he used that setting (he was using the same multimeter that we have) as opposed to the load test?jkjenn said:Michele, I have the same one. The black probe goes into the black hole. The red probe into the right side red hole. Turn the dial to the left to 12v. Place the re probe on the positive battery terminal and the black probe on the negative terminal.
https://youtu.be/GwyAd2DEkUA 2021 T@b 320 Boondock "Mattie Ross" | 2021 T@b Nights: 239 | Total nights in a T@b 455 | 2022 Jeep Grand Cherokee L Overland | T@b owner since 2014
Playc said:Hi ChanW -
1. Is the best solution to keep battery healthy while not in use and sitting for few weeks is to plug in AC 110 at all times?
2. The battery won't get a chance to discharge if it is on AC 110, then connect to Tow, then campground 30amp; Is it good for battery being charged to full all the time?
TIA
mickietucs said:Update --- multimeter reading showed it at 12.13-12.14 (inside voltage meter that's plugged into the dc receptacle showed 12.08 - not sure why the difference). Luckily there is an RV place immediately next door to the storage lot so I decided to talk with them since they're so close. They said they would pull the battery for me and charge it to bring it back up. Then I'll reconnect the trickle to keep it maintained.
Verna - I actually did a little test to see if I could lift it - I was able to, but not sure I'd be able to lift it all the way up and over the cover (I know I'd have to stand on something as I'm really short). On another note, I wonder if I need to get a hydrometer and use that if I have them take it to be charged. I just read that the multimeter doesn't really give the true state of a battery. Hmmmm....Verna said:mickietucs said:Update --- multimeter reading showed it at 12.13-12.14 (inside voltage meter that's plugged into the dc receptacle showed 12.08 - not sure why the difference). Luckily there is an RV place immediately next door to the storage lot so I decided to talk with them since they're so close. They said they would pull the battery for me and charge it to bring it back up. Then I'll reconnect the trickle to keep it maintained.
No two devices will of different manufacturers will have the same reading, Michele. .04 is not that much off. It just matters that your trickle charger has brought it up a bit. Good that there is a close RV place--keep a good relationship with them, they don't mind lifting heavy batteries
ChanW said:Michele, you shouldn't need a hydrometer. Yikes! You're getting really techy now! The shop could test it with one if necessary, but they'd probably just see how well it held a charge. ie: charge it up fully, then let it sit for 12-24 hours and see what the voltage is.
You're right about it being the best way to tell the condition of your battery, but really only necessary if you're having trouble with your battery. Yours is a new battery, so its ability to hold a charge will be a good enough indicator of whether it has a problem or not. You could detect weak cells in an older battery with a hydrometer however, which would let you know that you should think about replacing it soon.
I just watch for my battery to stop keeping a charge like it should (with nothing connected, of course).
I agree. You don't need to play telecommunications technician for the phone company! I don't miss that metallic taste in my mouth when I was using the hydrometer--YUCK!
Simple maintenance is what we do for our T@B's. Check the water level and keep it to the correct height. Watch your voltages to keep track of any potential problems.
I'm 5' 3 1/2" so I need a step stool for many things. I have one that stays in the truck bed. It's amazing if you ask for help (like the RV company next door to your storage lot), you normally get some help.
Oh yeah, have fun camping!
