jkjenn
Member Posts: 6,417
2014 T@B CS Maxx
Martha Lake, WA
If I don't blow something up, the credit goes to @normfun.
ie: If your battery is fully charged, you'll not see a very high draw measurement with your ammeter. And conversely, if your battery is greatly discharged, you'll see a high reading.
Your TV puts out what the Tab needs, up to the alternator's max rating.
If you're trying to get an idea of the maximum that your alternator can put out at any one moment, you'd probably need to get the specs for the alternator, or have it tested under load.
I guess I'm not sure what your asking.
J.D. & Sue
Since I had been wondering the same thing and what I did was put my multimeter in series between the XC90 and the T@B using patch cables with alligator clips on the pin that provides power to the trailer to get a true measure under load.
The XC90 puts out nearly 7A which is great for offsetting a little more than half of the fridge's 13A on 12v while towing.
I have no idea where he got his formula from or if it is even right, but I found this on a Jeep forum:
The reason I went all out to actually measure is the tech at our local T@B dealer told us the fridge would kill the battery on 12v while towing since the car would only put out about 2A. Knowing Volvos I seriously doubted that applied and also knowing the fuses in the panel were 10A to 30A depending on pin for the 7pin connector, I suspected it would be much higher (I think the e-brake pin is 30A just didn't recall what the one for "charging" was). I was happy I verified, especially since we were preparing for our big Alaska trip. I had hoped it would match the draw from the fridge. Having heard 2A is the norm (not just the tech but other posts here in the forums) and seeing ours at 6.7A, I was really happy!
You should measure your JK's max output charging current to be certain. If your Voltmeter has a setting for current (A) then you've got a multimeter and you can do the same test. You'd only need the patch/jumper wires since current is measured in series and has to be in the circuit being measured. Voltage is in parallel so typically you don't insert your multimeter into the circuit like you would for current (like I did).
Actual current cannot be calculated. A perfect example are the converters you'll find for electrical devices (like to power/charge a laptop); they're all rated for a wattage which is really only meant to mean maximum power. In reality the device will only draw a portion of that. Meaning at 120v if you have a power supply rated at 60W, it will provide a max current of 0.5A. The device in question may only draw 0.4A (48W) and never max out the brick/power converter. If it were to need more than 60W, then that's when problems start (overheating and even fires).
I'd be surprised if your TV was limited to only 7A output. A typical alternator will put out much higher amperage than that if it's needed - it's common to have a short 20 or 30 amp 'boost' immediately after the starter does its workr, because the starter has just drawn a lot of power out of your battery.
You can see this in any vehicle that has an ammeter on the dash. 2A is more like a maintenance or trickle charge.
http://cartech.about.com/od/Power/fl/Understanding-Alternator-Output-Ratings.htm
I'd be sure to disconnect the Tab before you use the winch though! Or at least turn off the fridge...
You got me wondering, with this thread, so I ordered a simple 12v watt/hour amp/hour meter, which's designed for these types of measurements (RV, solar, RC models, etc.)
It's called 'Watts Up'.
There's a cheap one on Amazon, and a more expensive one too, with the same capabilities. Looks like the cheaper one is less reliable, from the reviews. The better one comes highly recommended from those who know those things.
It'll measure your amps, watts, voltage, as well as accumulated consumption over a period of time, ie: amp/hours and watt/hours.
It would have to be installed in-line wherever you're trying to measure, like between the TV and the Tab, or between your solar panel and the Tab, etc.
The cheap one: http://www.amazon.com/Digital-Battery-Balance-Voltage-Analyzer/dp/B00EYZS6R6
The better one: http://www.amazon.com/Watts-Meter-Analyzer-WU100-Version/dp/B001B6N2WK
I'll let you know what I learn (if I learn anything B-)
Amps are always the same throughout the circuit, but there might be a voltage drop, if your wire isn't heavy enough for the load on the circuit.
I'll see if I can get to it tomorrow, if DW and DG don't get my time.
I did do a test with the "Kill a Watt" 120v watt meter. I measured the 120V usage with the fridge in both 120v mode and 12v mode. It showed what we already knew, that the fridge draws about 11-12Amps in either mode.
At the time I tested it, the fridge was near empty, I had pre-cooled it down to 35° beforehand, and the days were in the 80s, with nights in the 70s. In these conditions, the fridge had a 50% - 60% duty cycle in both 120V and 12V modes (I've installed the 12V thermostat relay mod that was mentioned earlier, so the 12V mode is not on continuously).
So that says to me that, in 12V mode, in those specific outdoor conditions, the fridge will draw at around a 7Ah rate (with minimal opening and closing of the door, and no adding any warm stuff to the fridge). (@mawebb feel free to correct me on all this, please!)
HTH
Have a great trip, Jenn!
The thermostat relay sounds like a great idea. You have to wonder why Norfolk don't build that into the fridges.
