2021 CSS clamshell T-Handles
Hi there! I have a 2021 TAB Boondock CSS and my clamshell t-handles accumulated some water and broke - I'm looking to replace. Has anyone had any luck with aftermarket parts by chance that I could simply swap out?
1.5inch mounting holes (center to center), 5/16 shaft, shaft length at least 3" and most importantly, I need the mounting base to be flush against the camper.
  • rfuss928
    rfuss928 Member Posts: 1,197
    That type handle is very common on the rear window of pick up truck bed caps. You may find some choices available at a local supplier of these.
  • Marceline
    Marceline Member Posts: 1,779
    eTrailer has a bunch of T-handles. This one looks about right, but I can't guarantee it.
