2021 CSS clamshell T-Handles
righteousgnar
Hi there! I have a 2021 TAB Boondock CSS and my clamshell t-handles accumulated some water and broke - I'm looking to replace. Has anyone had any luck with aftermarket parts by chance that I could simply swap out?
1.5inch mounting holes (center to center), 5/16 shaft, shaft length at least 3" and most importantly, I need the mounting base to be flush against the camper.
That type handle is very common on the rear window of pick up truck bed caps. You may find some choices available at a local supplier of these.
- 144 Events & News
- 76 Teardrop Groups & Links
- 921 Tips & Tricks
