T@B 320s 2019 fixing a leak
Hello folks, I have a problem that I uncovered back in May, but only starting digging into this, this past week. I posted a message back then, but could not try much.
So there is a definite leak behind the panel of the water closet. I have a picture to show the PEX that is definitely leaking when I turn on the city water. THe questions I have is around the PEX, and the way to pop off that connector. Is that a standard size, or something I can get from HomeDepot. I'm trying to understand if I need a special tool to pop the silver connector at the end?
Second question is around getting to work in that area. I removed 4 square insert screws off of the panel, in an attempt to remove the whole panel assembly. It didn't seem to let release anything. I can see there may be some strong caulk on the whole panel assembly to keep it water proof in that area. Is it just a matter of boxcutter the edges, and that should release it?
Thanks for any help you can provide.
Looks like I was able to replace the faulty line, and elbow by working thru the opening above the toilet panel. I thought it would be an issue getting in there. I was able to crimp connect 3/4 of the connectors , and I used a sharkbit for the last connection, since I couldn't get the crimp tool in there.
I might have the same problem…. How did you get the panel (I am assuming that it is the panel beneath the bathroom sink) off? How do those fasteners come clear without wrecking them?
Thanks!
I could be wrong (and someone please correct me if I am), but I don't think 2019 models had the bathroom sink, or the removable panel behind the toilet. I had to cut an access hatch in my 2015.
Hopefully someone with a newer model will chime in here. My impression is the panel is a little temperamental to remove, but it is removable. Isn't that how you check the glycol level in newer trailers?
2015 Nissan Frontier SV V6 4x40
