Trailer Hitch Question
Please enlighten me. On my last vehicle UHaul installed a Pilot Break Control along with the 7-way connector. Last week at another UHaul facility I had a hitch and 7-way connector installed. However they didn't install the Pilot Break Control. I have another appointment to have that installed. My question is ...is this item really necessary and if so is there a reason it wasn't done? Thank you.
  • Nomad
    Nomad Member Posts: 7,209
    edited September 2015
    I presume you mean "brake" control?
    Not all trailers require a controller so I presume that if you didn't specify that you needed one they wouldn't just install one.
    Yes, it is required as the T@B has electric brakes. Trailers over a certain weight are required to have brakes - This may be a state-by-state thing, not sure.
  • mawebb
    mawebb Member Posts: 257
    While the T@B is a lightweight trailer, it does have electric brakes and it is of benefit to be able to use them. Trailer brakes can help prevent brake fade on your TV and if the trailer starts to sway, actuating the brakes manually will get it back under control. I believe that each jurisdiction differs as to the maximum weight of the trailer before brakes are required, hence reason why U-Haul may not have installed the controller by default.
  • Tweedrvr
    Tweedrvr Member Posts: 122
    Thank you. That clarifies things a bit more for me.
  • mash2
    mash2 Member Posts: 584
    The above discussion assumes you have a little guy T@B trailer.  The older DM trailers have surge breaks instead.
  • RZRBUG
    RZRBUG Member Posts: 890
    Tweedrvr:  I'm assuming you have a newer T@B?  Mine is a 2013 and has surge brakes, thus no brake controller.
    Happy Trails Y'all
    States Visited Map
  • jkjenn
    jkjenn Member Posts: 6,417
    I believe they switched to electric inm2014.
  • Cyclonic
    Cyclonic Member Posts: 1,232
    Yes, it assumes that you have a 2014 or newer T@B.  T@B's older then that, with the exception of a very few of the last Dutchman T@B's, had surge brakes, which do not require a controller.  If it is newer it will need a controller.
    Sterling, VA
