Checked in at Blue Mounds State Park this evening with a full water tank, but discovered that nothing happened when I turned the WP on. Serious problem for some hungry travelers. I'm plugged in and all other appliances seem to work. Now I have no running water, hot or cold. The pump worked on my last trip. Any helpful advice would be greatly appreciated. All of the circuit breakers are switched to the on position.
                David -- Saint Paul, MN
2015 T@B-L "Silver Dr@ggin" towed by 2015 Kia Sorento V6 "Don Poulan"
0 ·
Maybe there are some other fixes I can make in the field? Anyone?
Seems I recall a thread where someone mentioned a filter on the pump - I've never checked. If there is and it's clogged I suppose it could create some kind of vacuume or something <- I'm grasping for possibilities here.
Too late tonight to give any of these ideas a try but will try in AM - at least to check filter and then maybe tap with rubber maller. Don't have voltmeter to trace circuit and probably couldn't really use it effectively anyway.
I'll let you know how I do and will continue to check for other great ideas
Thanks to all for your thoughtful and quick responses to my plea. I'll post a note after a solution has been found.
On Blue Mound - I grew up in that area and spent quite a bit of time down at the park beach (all the gals in their bikinis was a big draw :-) - My first band played it's first gig at the Hardwick Pavilion just north (made $250, lots of moola in 1963-4)
And Blue Mound Turkeys are the best - Had one every Thanksgiving.
Good luck. We learned there were a small batch of bad pumps that were installed after talking to the awesome people at the factory.
*hugs*
When I visited my dealer, he discovered that the pump was dead, probably having shorted out. The fuse light also was lit, though it seemed fine when I checked it in the field. Anyway, he replaced the pump and fuse. Interestingly, he didn't go to great lengths to determine specifically what was damaged. Rather, he said it was not a particularly good pump and substituted a brand that he said would be more trouble-free. My dealer sells a lot of LG units and I trust this opinion.
Others seem to have had problems with their pumps, so if a new pump seems needed, you might want to consider options to installing an identical model. For all I know, LG is now using a different pump than was installed in my 2015 T@B.
