I camp in some rough locales, so was concerned about securing my propane tank and battery. Simple mailbox lock at HomeDepot for under $5.00. Used a Step Drill from Harbor Freight for $6.00. 2021 T@b 320 Boondock "Mattie Ross" | 2021 T@b Nights: 239 | Total nights in a T@b 455 | 2022 Jeep Grand Cherokee L Overland | T@b owner since 2014
Jenn, apparently Pleasant Valley originally had locks, but had to stop installing them when advised of the ramifications of installing the lock. I have a rubber "do-dad" that holds my diamond plate lid on place.jkjenn said:My T@b came with a lock. How else would you keep it from flying open during transit?
If you happen to get the rubber do-dad, Jenn, warning....there is elasticity in the rubber and it pulls my hand back and I almost have a permanent cut in the web of my hand between my thumb and finger. I'm trying to re-educate myself to push the do-dad into place, rather than stretching it into place. Try it, you'll understand. Guys, your hands are stronger than mine, so this may or may not happen to you.jkjenn said:My lock, as a lock, I think is fairly worthless. As a matter of fact, it needs to be replaced. I wonder if the rubber do-dads would fit that hole?
I asked Marvin and Austin at Tearstock. They can't sell them.PXLated said:The simplest would probably be to just get a replacement part if LG has any - or directly from the mfg
I did when I first saw it and then remembered that twice, I just wanted to get and open up the propane bottle ASAP, as it was pouring rain.ChanW said:I like the combi lock idea - one less key - but then I'd have to find my glasses to open it... B-)
Does it latch if unlocked? I am looking to make sure it is secure while I am driving.mash2 said:Again, unless I'm concerned, I leave it unlocked. Under normal circumstances, it's not in the way.
Could also use some paint colors to create cover numbers and then just remember a color sequence (wouldn't need glasses).
That would be really awesome, if you have the time. Thanks!mash2 said:It has held on mine for 3 years.... Not sure how the new one's attached. On the DM's, it fits well. I have it tightened so that it has a positive hold that I need to rotate to open (not hard but it doesn't move unless I twist it. I could lock it, but it has been fine. If you want, I can try taking a picture of the reverse side of the mechanism so you could get a sense of the setup.
