So, I moved my little tank into the garage for the winter, (thanks to the wisdom of LARK and Sgt. John), and it revealed a valve that I could not identify. On the starboard side, just ahead of the wheel.  Anyone?
Emily
                emily . northern ohio . 2015 320s . jeep wrangler
There are a few threads in the forum about it, some with pictures, that might help...
Before I brought the tab in the garage, I drained the water lines, the Alde yellow relief valve was open, hot and cold valves were open, had the water pump on, opened the sink, shower faucets, flushed toilet, allowing water to drain into grey (gray) tank. Drained black, then grey tanks. I did not see the fresh water drain valve until I fiddled with my "get her in the garage" quest.
I am also guilty of adding pink to the fresh water tank. Tsk. Tsk. Live and learn.
I will be purposely putting the pink stuff in the fresh water tank next year and then using the water pump to circulate the anitfreeze. Like jkjenn said, it doesn't seem like a big deal to get the pink stuff out on the spring as long as you have a good supply of fresh water to flush it out. After all I went through trying to winterize for the first time this year, I have decided to put the antifreeze in the fresh water tank and pump it through.
