Well the install went pretty good. Fit perfectly. We measured and drill ed holes in the platform at home; then went to the T@B took the battery and propane out  and then took the Box off ( plenty of wire to move it to the side with it still connected to the Zamp plug) . We then dropped the platform on adjusted the location so the Box would line up with the holes and then the fun !! crawled under and drilled thru the angle iron of the trailer ( only issue was we had to remove the breakaway box to adjust the cables and then reinstall) All the bolts fir great except one that need a little help.
It look great and now we can put our generator on it and mount our antenna for the TV to it. Took about 3 hours for Kris and I to complete the work.
South Carolina
0 ·
South Carolina
We also have to get some 45degree and straight clear sewer hose connections so we can easily get at the dump tubes.
South Carolina
And use extreme care and caution when drilling through the frame and protect any wiring harnesses that run along and behind the frame, as it's back there!
Frank
South Carolina
Was the Salesman from a dealership or Sales from Little Guy. I think that the weight answer should come from Little Guy.
South Carolina
