I crawled under my T@b today to see if there was any water in the tank (if the dealer had put some in) and was surprised to see the whole area is covered (thought it was exposed). So now we can't tell how much water we have or am I missing something?
0 ·
You are talking the tank behind the step correct?
When I started, water was a big concern. You realize just how much we take unlimited water at the turn of a faucet for granted. Takes a little bit of reeducation to adjust. I've got it down where I can usually clean up after a meal (pots/pans, utincils, etc) on 2-3 cups of water.
In my 2013, the fresh water tank is under the cabinets. The only way to see it is to unload the cabinets, take out the shelf, and stick my head back under there with a flashlight. No, thank you. I don't need to know that badly. I carry a little extra in case I run out and don't worry about it.
Happy Trails Y'all
What Photomom said - "The 2016 we looked at had a sheet of some kind of dark material covering the entire undercarriage". As stated, guess I'll get a feel for how much is in there after several trips. Would like to empty it so a) I'm not traveling with a bunch of water that adds weight and b) then I can add it myself and know how much I'm putting in and then get a feel of how much I use.
It might be different with the 10 gallon tank but I honestly can't tell the difference with the 5 gallon tank.
If you don't see a valve handle but just the plumbing, the handle might have come off with travel - I've lost two so finally gave up and just use a pliers to open/close.
RollingLagrima - I had the pump on a bit and turned on the kitchen faucet - but it kept coming and coming (didn't seem to wane) so I shut it off as we were leaving for the balloon festival. Perhaps Tom's put in more water in mine than they did in yours.
