Shaking down our new tab only to find that colored side moulding broke over the winter...no contact just " sprung " from tension in how it was installed. Duct taped it down and contacted the dealer about a warranty repair. Really wondering how it happened. The TV was outdoors all winter with a cover from the little guy shop on to keep the snow off. Typical Colorado winter with wild temperature swings...wonder if that was the cause..Anyone else see this?
0 ·
I fled the MN winter so my T@B was spared the severity
We live in Cheyenne, Wyoming and were just sick when we took our cover off and saw the cracks but customer service was great at Little Guy.
I'm presuming you were then in communication with LG - What did they specifically say? "No more help from Little Guy" is a little vague.
Well, I tried to pull the pieces together and they would not budge. I don't think they are going anywhere.
Happened on both sides. I guess the T@B did not like the Phoenix 115 deg F. temps.
Durango, CO
Durango, CO
1. There should be a gap between the abs trim pieces, but it should still “line up”
2. The abs trim pieces are flexible and twist sometimes, but the upclose photos you sent in seem ‘off.’
3. The screws that hold it on are located inside of the keder rail, so that likely rules out anykind of stress/detachment
4. Finally – and I hope this is good news -The black rubber trim as well as the black ABS trim are aesthetic components only. They have no function except for looks. I just wanted you to know there is no cause for concern re: leaks. The extrusion that seals the sidewall and roof is underneath those pieces.
Durango, CO
Just can't believe a dealer wouldn't do warranty work, gives them a chance to interact with someone that could upgrade in a few years and talk them up to other potential customers - makes no sense.
The issue at the back end is a different matter. I've never seen that and don't know whether it could come loose. Hope Ed can give you some answers.
Happy Trails Y'all
I hadn't thought of the expansion issue but it may be so (however I don't think the door-side division is quite as wide. Yea, that back part has me more concerned. Don't think it can actually come off but it definitely needs to be secured somehow (both the plastic piece at the bottom and the rubber seal is loose from the body. I sent a note w/pics tonight to Ed.
Michele, I can't tell from your photos, but on the other side of the handle trim piece there should be a screw that helps hold the long trim piece in place. I've taken a picture of mine, both front and back of the T@B to show what I'm talking about. Maybe that screw has come loose? Also, caulk is not too good for holding plastic that has any strain on it. Shoo goo is the product most recommend. Won't take much. Its purpose is to repair shoes and should hold. There are several places that sell it, but I know that my local Wal-Mart has it hanging on a card rack back in the shoe department.
Happy Trails Y'all
Happy Trails Y'all
