Lexus RX
John_and_Kris
Member Posts: 302
Does anyone tow their T@B with a Lexus RX?
If so how did you deal with getting a 7 pin fully wired? We would like to get an RX next and then use a the RF Brake Controller?
South Carolina
South Carolina
I tow my T@DA with a Lexus RX450h (hybrid). The Lexus tow package did not include a charge line in the 7-blade connector. As you've realized, you need that for the Prodigy RF controller. I had Preston from Miller Trailer Sales wire a separate charge line to the auxiliary battery in the vehicle (not the hybrid batteries).Lisa. 2008 T@DA, previously 2012 6x10 SS. Southeastern PA
Thanks I 'm a little concerned about giving the manufacturer an out regarding warranty on a $50k car when you have to cut wires to install a 7 pin over the 4 flt pin.John - Kris & our Golden "Blossom"
South Carolina
Live simply,Love generously,Care deeply,Speak Kindly,Leave the rest to God -
Do not cut the 4 pin wiring. I used this adapter:
http://www.amazon.com/gp/product/B0002Q7C1C?psc=1&redirect=true&ref_=oh_aui_detailpage_o09_s00
I still have a flat 4 for my little boat trailer.
I slightly modified the included bracket to bolt directly to the existing flat 4 mount. That way, it is easy to put back to 100% stock and
Many small SUV's have an electrical box in the rear and you can tap a line in that. My Lincoln MKC had a spare 30A fuse just for this purpose. I only had to run the 10 GA wire (12 ga would be fine for that short of a run as well) from the fuse terminal dow to the 7 Pin socket. This was only about a 5' run total. I was careful to run the wire through he correct body grommet to make sure is could not short out on any metal.
Some times a little poking around in the rear compartment can save a lot of effort to run the wire all the way up to the battery...Kennesaw, Georgia
2016 Silver/Black T@B M@x S with Scuba Black interior. 2015 Lincoln MKC AWD 2.0L Ecoboost tow vehicle. Tekonsha Prodigy wireless Brake Controller. -
ThanksJohn - Kris & our Golden "Blossom"
South Carolina
Thanks for all the comments. We have a "15 GX and were thinking of downsizing to an RX. Will wait and see what the hitch etc is like on the new re-designed "16 Rx'sJohn - Kris & our Golden "Blossom"
South Carolina
I had the Lexus dealer install the 7 blade adapter prior to delivery.Lisa. 2008 T@DA, previously 2012 6x10 SS. Southeastern PA
Lisa33 What did you use for a brake controller? The GM at our Dealership said there should not be any problem doing this or with warranty as they will do it.
South Carolina
Lisa33 Sorry for the questions I now started up further and you answered all my questions. Sorry for the fat finger of K instead of LJohn - Kris & our Golden "Blossom"
South Carolina
John and Kris, Lisa has always used the Prodigy wireless brake controller.Verna, Columbus, IN
Thanks I gotta do more reading and less typingJohn - Kris & our Golden "Blossom"
South Carolina
The Prodigy is a sweet controller and easy enough to set up. I'm very happy with mine!Mike - Elmira, Mi / 2019 T@B 400 / 2021 Chevy Silverado LTZ
Thanks Mike. If we can get a good trade for our Lexus GX we will get an RX ( Kris wants to downsize) IF the dealership will put a fully functioning 7 pin on her.
We will use the Prodigy RF as I am sure Lexus will not want to cut wires at the dash.
Thanks againJohn - Kris & our Golden "Blossom"
South Carolina
- 920 Introductions
- 74 Teardrop Groups & Links
- 915 Tips & Tricks
