Lexus RX
Does anyone tow their T@B with a Lexus RX?
If so how did you deal with getting a 7 pin fully wired? We would like to get an RX next and then use a the RF Brake Controller?
South Carolina
  • Lisa33
    Lisa33 Member Posts: 260
    I tow my T@DA with a Lexus RX450h (hybrid).  The Lexus tow package did not include a charge line in the 7-blade connector.  As you've realized, you need that for the Prodigy RF controller.  I had Preston from Miller Trailer Sales wire a separate charge line to the auxiliary battery in the vehicle (not the hybrid batteries).
  • John_and_Kris
    John_and_Kris Member Posts: 302
    Thanks I 'm a little concerned about giving the manufacturer an out regarding warranty on a $50k car when you have to cut wires to install a 7 pin over the 4  flt pin.
    South Carolina
  • webcrawler
    webcrawler Member Posts: 133
    edited November 2015
    Do not cut the 4 pin wiring.  I used this adapter:
    http://www.amazon.com/gp/product/B0002Q7C1C?psc=1&redirect=true&ref_=oh_aui_detailpage_o09_s00
    I still have a flat 4 for my little boat trailer.
    I slightly modified the included bracket to bolt directly to the existing flat 4 mount. That way, it is easy to put back to 100% stock and
    Many small SUV's have an electrical box in the rear and you can tap a line in that.  My Lincoln MKC had a spare 30A fuse just for this purpose.  I only had to run the 10 GA wire (12 ga would be fine for that short of a run as well) from the fuse terminal dow to the 7 Pin socket.  This was only about a 5' run total.  I was careful to run the wire through he correct body grommet to make sure is could not short out on any metal.
    Some times a little poking around in the rear compartment can save a lot of effort to run the wire all the way up to the battery...
    Kennesaw, Georgia
    2016 Silver/Black T@B M@x S with Scuba Black interior.  2015 Lincoln MKC AWD 2.0L Ecoboost tow vehicle. Tekonsha Prodigy wireless Brake Controller.
  • John_and_Kris
    Thanks
    South Carolina
  • John_and_Kris
    Thanks for all the comments. We have a "15 GX and were thinking of downsizing to an RX. Will wait and see what the hitch etc is like on the new re-designed "16 Rx's
    South Carolina
  • Lisa33
    I had the Lexus dealer install the 7 blade adapter prior to delivery.
  • John_and_Kris
    Lisa33  What did you use for a brake controller? The GM at our Dealership said there should not be any problem doing this or with warranty as they will do it.
    Thanks
    South Carolina
  • John_and_Kris
    Lisa33 Sorry for the questions I now started up further and you answered all my questions. Sorry for the fat finger of K instead of L
    South Carolina
  • Verna
    Verna Member Posts: 6,876
    John and Kris, Lisa has always used the Prodigy wireless brake controller.
  • John_and_Kris
    Thanks I gotta do more reading and less typing
    South Carolina
  • Michigan_Mike
    The Prodigy is a sweet controller and easy enough to set up.  I'm very happy with mine!
  • John_and_Kris
    Thanks Mike. If we can get a good trade for our Lexus GX we will get an RX ( Kris wants to downsize) IF the dealership will put a fully functioning 7 pin on her.
    We will use the Prodigy RF as I am sure Lexus will not want to cut wires at the dash.
    Thanks again
    South Carolina
