Just about ready to order an Outback. I will be down sizing from a Motorhome but feel the TAB will be perfect for our dog show hobby.  Usually it's just two pugs and my self.  I do not have hook ups about 50% of the time, I am hoping the propane will be easier to use, and last longer? Am I correct that a 2000 sized generator will run my air conditioner?  Sometimes shows last 5 days....in a field/parking lot....no shade- I do use an easy-up for shade.  Seeking the best advice on keeping cool or keeping warm for two spoilt little pups
 So much excellent advice on here, I have really enjoyed the research.
Yep, a 2000w will work fine for the air. Actually, the 2000w is just needed for the startup of the AC then it settles into less of a draw.
Depending on temps, my propane lasts from one to three weeks when I'm heating it every night. If you don't need heat and just use it for cooking it lasts quite a long time.
For those times without hookups where you don't need air, you might consider adding a solar panel. I pretty much do dry camping most of the time and live off solar. I only bring out the generator for rainy days or to run the AC.
2016 Silver & Black Outback
Kilmarnock, VA.
Kilmarnock, VA.
Personally I don't feel any hardship not having them on my 2015. Ya kind of just get a feel for how fast you use water and how fast your tanks fill and the manual thermastat works fine.
I've had my Outback for a few months now and have really enjoyed it. However, I would NOT recommend this model unless you need the extra ground clearance. There is a significant price difference between the Outback and a normal TAB. The cool looking tire rack is just that - cool looking. Others on this list believe it can only carry an additional 24 pounds of stuff. Also, some have had bad experiences with putting a bike on it (like falling off while driving). The aluminum platform is a must have for me, but can be easily purchased separately and added to a normal TAB. Also, the two front stabilizer bars are too short to touch the ground because of the added ground clearance (very bad design). Just my two cents worth. Again, I really enjoy my Outback and do not regret the purchase one bit.
Frank
I've thought a lot about whether my next one would be an Outback or not and I'm not sure it would be.
Also, you can have a regular T@B retrofitted with the T@B axel - Jenn here on the forums had that done. So, you could start with whatever T@B you like and if you feel you need the clearance, have it retrofitted.
Take a breath and re think
"joho"
good luck and have fun the Forum is a great place to learn from
South Carolina
Kilmarnock, VA.
Kilmarnock, VA.
Also, not knowing if I was going to actually need it, I knew I could easily sell it - probably even one-on-one in a campground.
There's always something new coming/shipping. You'll never order if you wait for every new rumor/feature. And the minute you get your T@B there will be a new feature shipping.
Kilmarnock, VA.
Kilmarnock, VA.
Kilmarnock, VA.
Kilmarnock, VA.
South Carolina
Here is the Amazon review I was referring to:
21 of 25 people found the following review helpful
Seems to be an excellent inverter generator design
By David on June 16, 2015
Verified Purchase
Seems to be an excellent inverter generator design. I did have to re-gap the spark plug before it would start on one or 2 pulls as advertised. The specs called for .032 inch gap and the product came with the spark plug gapped at .028 inches. After re-setting the gap it starts easily. Now, however, I have to try and return it for a refund. Why? Well I purchased this as a source of power to go camping with. I live in the
Denver area and it runs fine here. However, the camping is in the mountains and I just learned the reason it would not start this weekend was that it can't run above 7,000 feet! We were camped at 7,500, and most places we travel with our RV are 8,000 and as high as 9,500. Westpro Systems tells me there is no replacement carburetor jet to fix this mixture issue, and therefore it's of no use to me. It would have been nice if their product information on-line, or the specifications on-line made some note of this altitude issue. If you live or play at altitude, buy something else.
another silly question....If using propane to heat, is this using the battery to fire the furnace constantly, or just start up ignition?
Kilmarnock, VA.
