Heat vents for the rear deck.
ChrisK
ChrisK Member Posts: 280
My latest project. The wife and I sleep with our heads to the rear of the trailer. Our pillows usually end up blocking the rear heat vents, We get heat but I can't help but think it is not as efficient as it could be like that so I drew up these vents in CAD, 3D printed them, and installed them in the back deck. They fit in a 2 1/4" hole (thats the biggest hole saw I had on hand). I tested them this morning and I could feel the heat coming from them so I guess they are doing as I wanted them to.
2014 T@b S Max AKA T@dpole
  • Nomad
    Nomad Member Posts: 7,209
    Cool - Covering up the standard heat slots with bedding really cuts down on the heat flow - There's another thread where several of us have drilled vent holes or slots in that same cover. Some of us added front rails so we could actually store stuff back on that shelf.
  • ChrisK
    I thought about just drilling holes but since I have a 3D printer, I have to overdo things.  =)
    We put stuff on the shelf at night.
  • ChrisK
    BTW - If anyone wants a set, let me know. I'm already making a set for OutbackAZ.
  • Nomad
    boo - As he mentions - He used a 3D printer.
  • ChrisK
    Yup, I print them. It was close to the same diameter but a little loose. I secured them with 2 small dabs of Shoe Goo.
  • Nomad
    Just out of curiosity - what printer and how long did it take?
  • ChrisK
    edited December 2015
    I built a Prusa i3 variant. It takes about 5 hours to print 4 of them. I also built an Ultimaker 2 clone that can probably print them faster but it was busy printing other stuff.
  • jdargis
    jdargis Member Posts: 305
    Looking for vents- check out on Amazon:
    Maurice Franklin louver vents
    different sizes and colors
  • jkjenn
    jkjenn Member Posts: 6,423
    I actually thing that back shelf is big enough for a register. You could then use a deflector.
  • Nomad
    But with reisters you would have to cut bigger holes and probably wouldn't be able to use the shelf as a shelf.
  • Verna
    Verna Member Posts: 6,876
    I would think you will need to worry about stability, because the normal register vent is too wide for the shelf. The register would go very close from front to back. With what I'm doing to the shelf, I'm having to put extra supports under it. Pictures later.
  • Tabaz
    Tabaz Member Posts: 2,420
    Just got my vents from Chris K.  The grey color matches the seat fabric. They look very professional and should let heat out while not allowing anything to fall down the holes. 2 1/4" wood drill should do the trick nicely.  Thanks Chris!
  • Ratkity
    Ratkity Member Posts: 3,770
    Great to hear Outback!! I love this forum! I have a set of vents on order. The cool-geek factor is a bonus. :)
  • Michigan_Mike
    Absolutely!  Love the ideas and creativity that flows within this group.....  Well done Chris!
  • Tabaz
    This section of the forum won't let me post a photo. Strange.
  • Verna
    The only reason it would stop you would be if the photo was humongous.  Make sure it's 800x600 pixels. There are many resize apps out there to help you.
  • Photomom
    Photomom Member Posts: 2,217
    How wide is that rear shelf? Standard floor registers from the home improvement store are 4" wide.
  • Nomad
    6 7/8" - depth
  • Tabaz
    Verna - the size of the photo is not an issue.  I always resize to 800 x 600 pixels before attaching.  When I click on the "attach image" icon, I just get a tan box with a cursor - no way to "browse" for the file I want to attach.  I've posted several photos in other discussions with success.
  • Nomad
    Verna - Just tried the file upload and got the same thing - just a url box with no option to go choose an image.
  • ChrisK
    Ah, I can finally get back in. Seems this forum is broken toSafari users. I have to dust off Google Chrome (shudders)
  • Nomad
    edited July 2018
    ChrisK - Haven't tried the forum on my Mac/Safari real recently but is working fine thru iPad/Safari. The forum software is not known to be real Apple friendly. Probably old crusty outdated PC code they can no longer really manage. There's lots of that out there unfortunately that can never be modernized.
  • Verna
    Sorry, Outback. I just tried it on my iPad and you are entirely correct. I should have listened to that little voice that said "try it before you answer!". I've sent a PM to Mike. This category was just created in the last few weeks, so it could be there is one option that wasn't checked.
  • ChrisK
    Yeah, I jad to put my images on my web space and link to them. Thought that was odd.
  • Verna
    Fixed!  Thanks, Mike!   (And yes, I know this photo has nothing to do with the subject, it was the last resized one in my library.)
  • Michigan_Mike
    There was a setting in the dashboard area (for this discussion area) that "some how" was switched off and this prevented the posting of photos to this discussion area....  Obviously things were working prior to the incident last night and hopefully all systems will remain normal.
    Thanks for bringing it to our attention!
  • ChrisK
    We are at McDowell mountain regional park this weekend and got to test the vents. At first, the Alde was putting out almost no heat on electric only. I switched to gas and it heated up really fast. I played with the wires going to the Alde and turned off the gas and all was well after that> might have a loose wire. I read another thread on this forum about that. Anyways, the vents worked very well. We could feel the heat coming out really well. Later in the night, I woke up and found all the side vents blocked by pillows but  the new top vents were pouring out heat.
  • Sgtjohn
    Sgtjohn Member Posts: 238
    They can build a T@B out of Legos, let's print out a T@B!
  • Nomad
    Sgtjohn ... 4 vents = 5 hrs ... 1 T@B = 2,438,195 hrs (just a rough estimate)
