Thanks to an owner who called me, and sent a follow-up email, we have the official answer from Ed at Pleasant Valley.
Do not dilute the glycol that is supplied by Pleasant Valley that goes in the Alde. It has already been diluted.
Also, per Ed, Pleasant Valley recommends changing your glycol , every two years.
0 ·
I suppose that covers replacing it as well.
100% propylene glycol eh? The only info I've been able to find about it sez that it will offer freeze protection to -74°F at 100%.
That ought to be enough, even for Ontario camping.... B-/ !!!
I think I can post a picture of the drain plug for it.
Odd that Ed says to use 100% glycol. The Alde manual specifies no higher than 50%.
I'll bet Ed is referring to the premixed 50% stuff.
Any chance you could confirm this Verna?
Deltaboy posted a bit from the Alde manual that conflicts with that, here's a clearer copy:
I'll try contacting Ed via email, with a copy of this Alde manual page, and ask him if he was referring to the pre-mixed glycol.
Don't want you stuck in the middle, ever! :-)
I checked Amazon and both pre-mixed and concentrated glycol is available. I suspect the factory has a supply of pre-mixed glycol available since they wouldn't want the workers mixing the glycol for every trailer. That may be what Ed's email is referring to. Probably wouldn't want to further dilute pre-mixed glycol.
It would be nice if that could be confirmed.
Photomom had it right. The Alde manual is what you should go by.
If you by non-diluted glycol, it should be diluted to the appropriate concentration.
If you buy the 50/50 premixed/diluted glycol, you should not dilute it.
The glycol at the LG factory is already pre-diluted, so should not be diluted further.
http://tab-rv.vanillaforums.com/discussion/comment/26120/#Comment_26120
Confirming what Ed stated in email referenced above. Every 2 years on glycol exchange.
